EAGLE User Support (English) Disable Splash Screen
  • Replies 10 replies
  • Subscribers 187 subscribers
  • Views 1344 views
There was a recent post about how to disable the you need to update
splash screen. Having searched for longer than I should have I will ask
if anyone has this info.
Doug
    TSVN/Settings/Advanced/VersionCheck
    Sorry, wrong program. Pre-morning-coffee bug hit again
    Coffee, it's not just for breakfast anymore.
    Lorenz
    That was it.
    Thanks to both of you,
    Doug
    On 4/5/2017 10:10 PM, Warren Brayshaw wrote:
    You could be meaning that you don't wish Eagle to check for updates. In
    that case.
    Control Panel > Help > Check for update... > Configure > Never
    HTH
    Warren
    That was it.
    Doug
    that case.
    HTH
    Warren
    that case.
    HTH
    Warren
    EAGLE support forums at http://www.eaglecentral.ca :: Where the EAGLE community meets.
    that case.
    HTH
    Warren
    Lorenz
    Lorenz
    Which version of Eagle and OS are you asking about?
    I suspect the splash screen was removed in v7.7 as I don't get one (Win7)
    but I can still get one with v7.6. So if v7 is what you have, install 7.7
    and you should be all good.
    Warren
    Warren
