EAGLE User Support (English) dropping in exact part (different pin labels) without re-routing?
  • Subscribers 187 subscribers
  • Views 820 views
unebonnevie
unebonnevie over 9 years ago
I have PDIP two parts, say, A and B, both of which have exact pin count and footprints, etc.  Their IO pins are different.  I created a schematic and routed BRD file with part A.  Now, how would I substitute part A for B to the schematic without doing the routing of the traces again on my BRD file?  The traces are the same, except the labeling.
Thanks!
    Am 10.04.2017 um 09:03 schrieb Hans Lederer:
    Am 09.04.2017 um 19:56 schrieb Mr. uC:
    HELP REPLACE
    You generate two library devices which have the same PACKAGE, i.e. the
    same footprint and (important!) the same pad names.  If they are in the
    same library, just use the same package; else, copy the package to the
    new lib.
    When you just delete Part A in your schematic and then insert Part B,
    (only) the last segment of your traces to the part will be ripped up and
    have to be rerouted.
    When you REPLACE it in the board, you will have to choose whether to
    reconnect the same pin names or the same pad names — in your case, the
    latter.  No ripup and rerouting then.
    HTH, Hans
    Sorry, that was simply wrong.  One should look it up instead relying on
    a old grey storage…
    Do create your part B with exactly the same PACKAGE (so the board will
    not be changed) and a SYMBOL that may have different pin names, but has
    its pins at the same spatial coords as part A (copy part A's symbol and
    only change the pin names).
    Then, in your schematic, REPLACE part A by part B, choosing “same
    coords”.  Done without ripup and rerouting.
    HELP REPLACE
    new lib.
    HTH, Hans
    a old grey storage…
    HELP REPLACE
    new lib.
    HTH, Hans
    HELP REPLACE
    new lib.
    HTH, Hans
    HELP REPLACE
    new lib.
    HTH, Hans
    You create the second device, (the B item), in the library as it will have
    a different part number. When you place that device in the schematic the
    correct package appears on the board., displaying the desired labels.
    HTH
    Warren
    EAGLE support forums at http://www.eaglecentral.ca :: Where the EAGLE community meets.
