EAGLE User Support (English) where to find farnell component to add to schematic
  • Subscribers 180 subscribers
  • Views 836 views
  • library
  • component
I'm trying to find a component through the add component feature of Eagle. Here is the Farnell part
  • Manufacturer:CAMDENBOSS
  • Order Code: 2493625
  • Manufacturer Part NoCTB0709/2CTB0709/2
I can't find this component in the available components list in Eagle, any ideas anyone how I add this component to my schematic?
thanks in advance
    If it's not in the bundled libraries and Google doesn't help then you must
    create it yourself using the library editor. This is explained in the
    manual and there are many great tutorials just a quick search request away
    which will take you from the basics through to more advanced part creation
    topics. Here are a couple worth looking at:
    http://dangerousprototypes.com/2012/03/07/how-to-make-parts-in-cadsoft-eagle/
    https://learn.adafruit.com/ktowns-ultimate-creating-parts-in-eagle-tutorial/introduction
    If you are doing any serious board design work with Eagle I would
    personally recommend you create your own library of parts which are
    consistent and specific to your needs rather than using the bundled
    libraries. These are great for providing a lot of parts and examples of how
    to do many different things but they vary wildly in quality and there is no
    consistency so schematics draw using the them will likely look a bit of a
    mess and there are no guarantees that all the PCB footprints are correct
    and will work for your (or your CM's) manufacturing process. Creating your
    own libraries takes a bit of time early on to get all the basics in place
    but once you've started to build up a number of parts in there then
    creating new ones starts to become a quicker and easier task.
    Former Member over 10 years ago in reply to autodeskguest
    Great image thanks for the links, very helpful indeed. Finished my project image
    autodeskguest over 10 years ago in reply to Former Member
    You're welcome. Glad to hear the links were useful and you got your project
    finished image
