EAGLE User Support (English) Improve the SHOW command part highlighting in the board editor
  • Views 954 views
  • improvement
  • board_editor
  • show
  • suggested
martonmiklosqdev
martonmiklosqdev over 9 years ago
When populating boards by hand I usually use the SHOW command with the @ argument.
It works well with a single component:
But there is an use case when I would like to highlight multiple parts (with the same value):
In this case the EAGLE draws one big rectangle, but showing separate rectangles would make more sense like on this gimposhopped image.
To not "break backward compatibility" I would recommend to implement this separate rectangle behavior only when each part name is suffixed with a @
Like SHOW R1 R2 R14 @ should show a single rectangle, while SHOW R1 @ R2 @ R14 @ should show them separately.
  • martonmiklosqdev
    martonmiklosqdev over 9 years ago in reply to autodeskguest
    I have upgraded this ULP a bit: I have added ability to show parts in only top/bottom sides:
    https://github.com/martonmiklos/ulps_for_eagle/tree/master/show_values
  • martonmiklosqdev
    Thank for your reply Jorge! I am very pleased to see such an improvement.
    autodeskguest over 9 years ago in reply to martonmiklosqdev
    On 4/24/2017 5:00 PM, Miklos Marton wrote:
    Thank you so much Warren for your ULP!
    I agree with you on the fact that the gray out would be a better (and less clutterish) approach to highlight parts.
    I hope this issue will get the Autodesk's attention because I think it would not be so hard to implement.
    https://www.element14.com/community/message/221170
    Hi Milos,
    It has our attention, stay tuned.
    Best Regards,
    Jorge Garcia
    Autodesk Support
    We have a new forum here <http://forums.autodesk.com>
  • martonmiklosqdev
    https://www.element14.com/community/message/221192
    In my opinion a whole bunch of rectangles are not the answer. What you
    need is high visibility of the location of the parts of interest,
    without clutter.
    Previously I have proposed previously that during 'show' the board view
    is greyed. It is the low light colours that are greyed. This is how
    Altium do it and where the idea came from.  Highlight colours remain as
    you have set them in your palette so the items you 'show' are very obvious.
    I'll attach an image which E14 users will need to go to eaglecentral to see.
    http://www.eaglecentral.ca
    In my world, a ulp toggles between the grey and normal palette.
    A second ulp, showvals_Eagle_7 downloadable form autodesk
    http://eagle.autodesk.com/eagle/download/1776
    locates the common value you wish to highlight.
    In the attached I keyed in the value 100nf to locate the 100nf capacitors.
    Warren
      ... use NNTP://news.cadsoft.de and a functional news reader like
    Thunderbird!
    ... or http://www.eaglecentral.ca browser access to CadSoft EAGLE
    support forums.
    This email has been checked for viruses by Avast antivirus software.
    https://www.avast.com/antivirus
