EAGLE User Support (English) zoom inside the border
  • Replies 7 replies
  • Views 881 views
I have a circuit diagram drawn inside a border.
The diagram takes up about a quarter of the border and prints that way.
Is there any way of increasing the size of the circuit diagram inside the
border?
EAGLE support forums at http://www.eaglecentral.ca :: Where the EAGLE community meets.
    I thought I set it at more than 1.4 and got it outside the page?
    I have just tried it again and set it to 1.5 and it fills the page
    correctly.
    Even setting it to 8 fills the page correctly?
    Thanks for the tip I will do that.
    mat wrote:
    Just for anyone elses benefit.
    Thanks Rachael, I didn't know there was a manual frame.
    I deleted the frame and left the title box intact.
    I then moved the title box closer to the drawing and drew a frame around
    the outside.
    Pressed file/print and altered the border to 1mm alround.
    I then experimented with Scale factor and found this altered the size on
    the page, Scale factor 1.4 gave me a full page.
    With the help of members on here anything is possible.
    if you don't require/need to know a/the specific scale factor, just
    set 'Scale factor' to something big and 'Page limit' to 1.
    Lorenz
    the outside.
    Lorenz
  • rachaelp
    rachaelp over 9 years ago in reply to autodeskguest
    You're welcome. I'm glad you got your problem solved!
    the outside.
    Thank you.
    Thank you Rachael.
    I am playing with that and discovered there is a smaller frame I can use
    FRAME_A_L   It doesn't let the drawing fill the frame but it is a lot
    closer. Thank you.
  • rachaelp
    matelot2 wrote on Tue, 16 May 2017 15:30
    way.
    the border?
    Rather than increase the circuit (the library parts are all drawn to a
    specific size) you'd be better off just deleting the existing border and
    drawing a smaller one. You can use the FRAME command to manually draw the
    page frame and then add additional text / lines to it for the other legends
    or you could use a standard frame from the frames.lbr, or make your own
    frame library, etc....
    Best Regards,
    Rachael
