EAGLE User Support (English) changing fonts
  • Views 515 views
changing fonts
matelot
matelot over 9 years ago
reading through past topics I have found quite a few with reference to
fonts and vector fonts.
I can not find anywhere to control these.
I am aware Eagle uses a limited number of fonts but hope I can find one
that supplies things like numbers in circles?
Would someone mind running me through being able to change the font I can
use when entering text (if this is possible) and hopefully help me go to
one that gives me numbers in circles?
thanks.
EAGLE support forums at http://www.eaglecentral.ca :: Where the EAGLE community meets.
  • matelot
    Thank you Jorge. I suppose the only thing I would like now is one of the
    fonts that includes numbers with circles around them adding to the
    available fonts. hopefully replacing the numbers one for one. :?
    thanks.
    Hi Mat,
    EAGLE currently comes with 3 fonts proportional, vector, and fixed. They
    basically use the ASCII character set that doesn't include too many
    fancy characters. If you need numbers with circles in them the easiest
    way to do this is to draw it in manually.
    Using the text command enter a number, make sure to center justify the
    text. Then using the circle command draw the circle with it center on
    the center of the text. That's going to be the best way to do it for now.
    Please let me know if there's anything else I can do for you.
    Best Regards,
    Jorge Garcia
    Autodesk Support
    We have a new forum here <http://forums.autodesk.com>
