EAGLE User Support (English) Part from pcb
  • Views 794 views
Part from pcb
mariusl
mariusl over 9 years ago
Hi
How do I go about to create a part from a pcb. I want to use and Adafruit module as a plugged in part on my pcb.
I have the Adafruit design so now I am trying to make a part of that module's pcb.
  • mariusl
    mariusl over 9 years ago in reply to autodeskguest
    Thanks Warren that is exactly what I was looking for. Easy when you know how.
    autodeskguest over 9 years ago in reply to mariusl
    On 14/06/2017 5:20 a.m., Marius Liebenberg wrote:
    That is what I ended up doing. Just made a part of my own. There is a script for doing though but it fails and I dont have enough knowledge of Eagle to try and fix it. I attached it if anyone want to have a look. If it worked it would have saved a lot of time.
    https://www.element14.com/community/message/224053
    hierarchical_v1_1.zip
    The ULP to use is make-group2pac.ulp
    Grab the Adafruit board file and open it in Eagle.
    Remove all except the board outline, and elements that give you the
    pads, tPlace and mounting holes you need.
    Group the remainder and run the ulp.
    It will make a package that you can place into your design. The rest of
    the devise can be built as desired.
    Attached: Image of the result of the process.
    HTH
    Warren
    ... use NNTP://news.cadsoft.de and a functional news reader like
    Thunderbird!
    ... or http://www.eaglecentral.ca browser access to CadSoft EAGLE
    support forums.
    This email has been checked for viruses by Avast antivirus software.
    https://www.avast.com/antivirus
    HTH
    Warren
    Thunderbird!
    support forums.
  • mariusl
    mariusl over 9 years ago in reply to shabaz
  • geralds
    geralds over 9 years ago
    Which part do you like to create?
    May be that this part may exist.
    Gerald
    shabaz over 9 years ago
    Hi Marius,
    Just measure the pin locations, and create a new part in EAGLE with pads in the correct places. In other words, it can be treated much the same as for creating any arbitrary new component in EAGLE.
    If your adafruit module has pins on a standard pitch, it is likely to be 2.54mm.
    To see how to create a part in EAGLE, see the EAGLE user manual PDF guide, or there are many youtube videos on this subject.
