EAGLE User Support (English) Find drill by size on PCB
  • Subscribers 187 subscribers
  • Views 863 views
Does anyone know a quick way to find a drill on the board by size?
I have a fairly good size board and have two drills almost exactly the
same size and would like to merge them.
I did not have control of the library parts so have no idea what part(s)
the odd size drill is in.
Staring at the sea of drill symbols on a large board is not an
attractive option.
Ideas anyone?
Doug
This email has been checked for viruses by AVG.
http://www.avg.com
    On 7/11/2017 10:28 PM, Warren Brayshaw wrote:
    You could use the following ULP, downloadable from
    http://eagle.autodesk.com/eagle/download/2087
    drillinfo.ulp
    Then you will know which part has the drill size of interest.
    You will still need to get at the library to change it but this is possible
    by exporting the libraries from the schematic or board. There are few
    precautions needed to achieve this.
    You may not need to do anything. The manufactures often only drill to their
    drill sizes and if your two sizes fit within the one range they will be
    drilled with the same drill - job done.
    HTH Warren
    Thanks Warren.
    My problem came in when there were too many drills and Eagle ran out of
    symbols.
    When I looked at the sizes they were about 0.16 mil apart.
    Fixing was easy, finding was the challenge.
    Thanks for the suggestions. It is happy now.
    -D
    http://www.avg.com
    drillinfo.ulp
    HTH
    Warren
    EAGLE support forums at http://www.eaglecentral.ca :: Where the EAGLE community meets.
    On 7/11/17 7:46 PM, Doug wrote:
    > Ideas anyone?
    Why not open the .brd file in an XML or text editor?
    You should see lines like these:
    Dietmar
