EAGLE User Support (English) Is it possible to add a   document number
  • Subscribers 189 subscribers
  • Views 1271 views
matelot
matelot over 9 years ago
I have managed to manipulate borders, with help from contributors to this
web site.
I notice in the title box there is a blank 'Document Number' box, is it
possible to put something somewhere in Eagle to fill this and if so how?
I notice the title of the file shows up in the title box and the date
changes every time you alter the file.
EAGLE support forums at http://www.eaglecentral.ca :: Where the EAGLE community meets.
  • matelot
    matelot over 9 years ago in reply to rachaelp
    Thank you Rachael, that was what I was wanting.
    I don't come to the e-mail that this site is set to very often, sorry for the delay but thank you anyway.
    Bob.
  • rachaelp
    rachaelp over 9 years ago in reply to autodeskguest
    Rob Pearce wrote on Fri, 14 July 2017 08:22
    That said, it is possible (V5 onwards?) to embed attribute values in
    symbol text within the library. The limitation is that attributes
    apply
    to parts, not the schematic (or project) as a whole. You'd still have
    to
    set the attribute on the frame of every sheet.
    Global attributes work across the drawing, so set it in the schematic and
    it's set on every sheet. You have to doit separately for the layout, but
    you would want that different anyway as the layout would want to have a
    different document number to the schematic.
    Best Regards,
    Rachael
    web site.
    The document number is not handled automatically (at least, not on
    versions I've used a lot, there may be some V7 or V8 changes to this).
    Instead you can simply place a text annotation in there. Use the text
    tool, select a suitable font size and the layer that matches the border,
    and place the text.
    symbol text within the library. The limitation is that attributes apply
    to parts, not the schematic (or project) as a whole. You'd still have to
  • rachaelp
    You can add a global attribute from Edit->Global attributes.... and call it something meaningful like DOC_NUM in this example or whatever you like with the appropriate value for your document. Then in your frame library part, add text element containing the text >DOC_NUM (or whatever you used, just make sure it starts with a >) and place it in the document number box.
    Best Regards,
    Rachael
