EAGLE User Support (English) bq25505
  • Replies 12 replies
  • Views 1751 views
bq25505
ambush
ambush over 9 years ago
Hi :-)
i need the package bq25505 for Eagle cad.
Where can i find it?
regards
  • geralds
    geralds over 9 years ago in reply to ambush
    Hi Silvio,
    please refer to the drawings in the datasheet, also the drawings in the additional information.
    There will be described how you can draw your footprint.
    Here in this drawing the pad has a template at the inner side a round shape and at the outside a rectangle.
    So you easy draw this - a SMD round pin and a polygon connected on this round pin (this polygon gets the same pin name, number).
    Please read also the Eagle manual - "how to create complex SMD pins"...
    After that - make 5 copies at X-angle from left to right (from east to west, then 5 copies Y-angle from bottom to top (from south to north),
    then 5 copies on  north from west to east, and last 5 copies from north to south on the east side.
    In the middle then you create the exposed pad.
    All of them the pins are around the middle center point.
    The center point - 0,0 margin, is also the point for pick up the device with the assembling machines!!!
    After that you can draw the cream layer template.
    Be careful with the grids. - If the datasheet shows you in mm then you set a fine grid in mm
    (eg. the pin grid is 0.5mm - then make the dimension grid so fine that you can divide into this grid without rest. ->> n / 2 = xxx.xxxxx)
    For me i calculate to fine grid 5 numbers after comma. This allows you to multiply back to the top number at any time.
    ->>> see also inch / mm.
    ->>> see also top or bottom, right or mirrored
    Eagle looks every time from top to bottom.
    You know about Mr. Wilhelm Conrad Röntgen?  image That is what you need in your eyes.
    Do you know the mirrored focussing? Well it's a very fine feeling. image
    I wish you all the best.
    After that we can talk once more.
    Best Regards
    Gerald
  • ambush
    ambush over 9 years ago in reply to geralds
    Hi mr Gerald,
    thanks for your opinion, i know that symbol is missing ;-) i'm drawing it.
    where are the package and foot-print wrong? only pin/pad?
    thanks again
    regards
  • ambush
    ambush over 9 years ago in reply to autodeskguest
    Hi mr. Paschedag,
    I renamed the pins from 1 to 20.
    thanks a lot
  • geralds
    the part is wrong.
    Also the footprint is wrong.
    A device have pins that begins from 1 not from elsewhere and goes numbering to the last pin; here the exposed pin will get the last pin number.
    Also it is missing the symbol also the connection to the footprint.
    The symbol can have pin names instead of pin numbers, because that are functioning names. Then the schematic will be easier to read.
    http://www.ti.com/lit/ds/symlink/bq25505.pdf
    Here have you some additional information for developing your footprint:
    http://www.ti.com/lit/an/slua271a/slua271a.pdf
    Every time it is necessary you have this information in the background in your brain,
    even if you have not directly to do with this, but you have global information you can talk about.
    If you use the advanced editor you can attach files.
    If you haven't a packaging program:
    www.winzip.com
    Best Regards,
    Gerald
    bq25505.zip
    autodeskguest over 9 years ago in reply to ambush
    Am 30.07.2017 um 09:55 schrieb Silvio Di Cioccio:
    Good morning mr. Paschedag,
    this is the package file.
    https://univaq-my.sharepoint.com/personal/silvio_dicioccio_student_univaq_it/_layouts/15/guestaccess.aspx?docid=17ddbbf055d5440bdbd891e3ecf175124&authkey=AZafNT6VemtIRSiDBASGpyo&expiration=2017-08-29T07%3a51%3a01.000Z
    thanks for your help
    regards
    Silvio Di Cioccio
    https://www.element14.com/community/message/226251
    I had a short glimpse at your file and it looks quite OK.
    You should observe that the pad numbers in the data sheet are given at
    bottom view.
    Eagle is always looking from top! Body size is OK but I didn't check the
    pads. Attached is a suggestion that might help you (pads renumbered) image
    Joern Paschedag
    bq25505-1.zip
  • ambush
    Hi Gerald,
    I'm sorry, but I can not upload this file as zip.
    Can you explain me how can I do it?
    regards
    Silvio
  • geralds
    Hi Silvio,
    you don't need a link you can upload a file as zip file because the lib file was not allowed.
    For me, i don't click to this unknown link there, a lot of virus may be on there.
    Gerald
  • ambush
    regards
    Silvio Di Cioccio
    Am 29.07.2017 um 10:32 schrieb Silvio Di Cioccio:
    I'm sorry for the tone used in my previous e-mail image I did not want to look arrogant or look like someone who pretends things that are already ready. Sorry again.
    In fact I have already created my component eagle file, I just wanted to compare it with an official.
    Thank you for your reply.
    Yours sincerely
    Silvio
    https://www.element14.com/community/message/226219
    No Problem image
    I didn't find any library but if you upload your work I might have a
    look and compare it with the data sheet.
    Joern Paschedag
  • ambush
    I'm sorry for the tone used in my previous e-mail :-) I did not want to look arrogant or look like someone who pretends things that are already ready. Sorry again.
    Yours sincerely
    Silvio
