EAGLE User Support (English) No way to use alt grid in route command in Eagle 8.2.2
  • Views 839 views
This worked in Eagle 7 but not anymore in 8.2.2.
It used to be possible change between normal and alternate grid in routing
pressing ALT-L key.  This doesn't work anymore, ALT-L does nothing when routing.
In other commands, like MOVE and LINE, it still works.
How can I change between normal and alternate grid when routing?
     /alo
  • rachaelp
    rachaelp over 9 years ago in reply to autodeskguest
    Antti Louko wrote on Mon, 07 August 2017 21:52
    rachaelp wrote:
    Yep it's a known issue which will be addressed in 8.3.0 which I
    believe will be ready fairly soon.
    OK. Thank you!  I can live with that until then.
         /alo
    It looks like you didn't have to wait too long, EAGLE 8.3.0 has been
    released!
    Best Regards,
    Rachael
    EAGLE support forums at http://www.eaglecentral.ca :: Where the EAGLE community meets.
  • rachaelp
         /alo
    released!
    Best Regards,
    Rachael
    autodeskguest over 9 years ago in reply to rachaelp
    rachaelp wrote:
    Yep it's a known issue which will be addressed in 8.3.0 which I believe will be ready fairly soon.
         /alo
  • rachaelp
    To work around this until 8.3.0 is released you can set up two grids with the command line:
    GRID mm 0.125;
    GRID mm 0.25;
    Then you can issue the command:
    GRID last;
    to switch between these two grids.
    Alternatively set up some grid commands on hot keys with the ASSIGN command and switch between different ones as you need.
    Best Regards,
    Rachael
