EAGLE User Support (English) No way to use alt grid in route command in Eagle 8.2.2
  • Views 766 views
This worked in Eagle 7 but not anymore in 8.2.2.
It used to be possible change between normal and alternate grid in routing
pressing ALT-L key.  This doesn't work anymore, ALT-L does nothing when routing.
In other commands, like MOVE and LINE, it still works.
How can I change between normal and alternate grid when routing?
     /alo
  • e14softwareuk
    e14softwareuk over 9 years ago
    Just to let you know that version 8.3 is out with the bug fixed so probably best to just go with the latest version now.
  • rachaelp
    rachaelp over 9 years ago in reply to e14softwareuk
    Peter Barnard wrote on Tue, 08 August 2017 13:33
    It seems to be difficult to download the older version from your
    Autodesk account, the following link may work
    http://trial2.autodesk.com/NET17SWDLD/2017/EGLPRM/ESD/Autodesk_EAGLE_8.2.1_
    English_Win_64bit.exe
    https://www.element14.com/community/message/226889
    You can download earlier versions of EAGLE from here:
    http://eagle.autodesk.com/eagle/software-versions
    EAGLE support forums at http://www.eaglecentral.ca :: Where the EAGLE community meets.
  • rachaelp
  • e14softwareuk
    If you need to download an old version to workaround this bug you can do this from http://eagle.autodesk.com/eagle/software-versions.
  • e14softwareuk
    Hi. To switch grids in 8 you just need to use the ALT modifier key. There does appear to be a bug introduced in 8.2.2, using ALT to switch to the alternate grid whilst routing works in 8.2.1 but in 8.2.2 the grid shows as switching but the routing stays on the normal grid.
