EAGLE User Support (English) How to change text alignment with script (console command)? [SOLVED]
  • Replies 10 replies
  • Subscribers 190 subscribers
  • Views 2618 views
  • ulp
  • align
  • text
MaxKielland
MaxKielland over 9 years ago
I'm writing a script (ULP) to smash all Resistors, Capacitors and Inductors and then set the text alignment to "Center" and move it to the origo of the package.
Now I'm stuck on how to change the text alignment, I can't find any command to do that.
Bonus question: How do I un-smash a smashed component in ULP?
  • josephoney
    josephoney over 6 years ago in reply to autodeskguest
    Lorenz,
    Thank you so much for this help!!
    This is what I need. I am starting with ULP, but needed this tool.
    Regards
    Jose M
    autodeskguest over 6 years ago in reply to josephoney
    josephoney wrote:
    Hi Max, could you share the ULP to align text to device? If possible, thanks!!
    to group all parts and smash:
         display none 23 24; group all; display last;
         smash (>0 0);
    group all parts names and set align to centered:
         display none 25 26; group all; display last;
         change align center (>0 0);
    to align the part names to the part origin (this is the part you realy
    need an ULP for, because you need to place the text origin onto the
    part origin. That is you need to generate a "move part-name>name
    (part-x part-y);" command for each part):
         string s, cmd;
         board(BRD) BRD.elements(ELM) {
           sprintf(s, "move %s>name (%fmic %fmic);",
             ELM.name, u2mic(ELM.x), u2mic(ELM.y));
           cmd += s;
         exit(cmd);
    Lorenz
  • josephoney
  • MaxKielland
    MaxKielland over 9 years ago in reply to autodeskguest
    This did the trick, thank you! In this way we are not pending on the grid setting.
    autodeskguest over 9 years ago in reply to MaxKielland
    Max Kielland wrote:
    Thank you but what if the grid changes from mil to mm?
    When I changed the grid units I got the same numbers (the old mil).
    Isn't there a way to get the coordinates right independent of the grid
    unit settings?
    use (using microns here, but ich, mil & mm are also possible)
         sprintf(s,"ch al ce (%fmic %fmic) %s;",
              u2mic(T.x), u2mic(T.y), E.name);
    just put the unit explicitly in the command string.
    have a look at  Help/Editor Commands/Command Syntax  for the
    coordinate syntax
    Lorenz
  • rachaelp
    rachaelp over 9 years ago in reply to MaxKielland
    When I changed the grid units I got the same numbers (the old mil). Isn't there a way to get the coordinates right independent of the grid unit settings?
    GRID mil; <do stuff...>; GRID last;
    Best Regards,
    Rachael
  • MaxKielland
    MaxKielland over 9 years ago in reply to rachaelp
  • rachaelp
    Hi Max,
    You'll need to use the u2mil() function to convert the integer values you are seeing into the mils you are using.
    Best Regards,
    Rachael
  • MaxKielland
    Thank you, now it seems like the coordinates are all strange.
    For example:
    (snippet from ULP script)
            E.texts(T) {
              sprintf(s,"CHANGE ALIGN CENTER (%d %d) \\\\ %s\n", T.x, T.y, E.name);
    Grid units are in mil
    My resistor R4 (smashed text) at X: 537.5 Y:650 (when looking at it's info in the PCB editor)
    But my ULP script outputs:
    CHANGE ALIGN CENTER (4368800 6096000) \\ R4
    CHANGE ALIGN CENTER (3413760 5364480) \\ R4
    These X,Y values are completely wrong and according to the documentation they should be in the same units as the current grid, in this case mil.
    When trying to use these coordinates I get "Invalid Point: (...)"
    [EDIT]
    I realized that the coordinates are real numbers so I changed the sprintf formatting to:
    sprintf(s,"CHANGE ALIGN CENTER (%f %f) \\\\ %s\n", T.x, T.y, E.name);
    But that generated a formatting error when I run it.
    I then tried a typecast
    sprintf(s,"CHANGE ALIGN CENTER (%f %f) \\\\ %s\n", real(T.x), real(T.y), E.name);
    But that generated the same numbers as before, but with a lot of 0 decimals.
    I calculated the factor to 8128 and when I divided the coordinates with this they became correct.
    I must be doing something wrong here... How is it supposed to be handled?
    command to do that.
    in the ulp use "setgroup" to group all relevant texts (name, value,
    attributes?) then exit the ULP with
         change align centre (>0 0);
    (not tested though, does setgroup work with attributes at all?)
    or
         change align center (x y) ...
    where "x y" are the origin coordinates of a text
    group the relevant parts then run "smash (>S0 0)"
    or
         smash (S x y)
    where "x y" are the origin coordinates ot the part to unsmash
    Lorenz
