EAGLE User Support (English) tStop Polygon Causes DRC Errors
  • Subscribers 182 subscribers
  • Views 631 views
rossw
rossw over 10 years ago
I'm trying to create a heat sink under a 7806 voltage regulator by drawing
a polygon in the tStop layer around the metal tab (I'll use heat sink
grease and maybe a nut & bolt to make a good connection). I want to add
vias to transfer the heat from the top layer ground plane to the bottom
layer ground plane. The problem is that when I add a polygon in the tStop
layer (so there's no solder mask under the metal tab, just bare metal) it
then causes multiple DRC errors on layer 29. I can't get rid of those DRC
errors even if I remove the polygon (either by CTRL-Z or manually delete
it). What am I doing wrong?
(Ignore the red-dotted polygon around the device - that's not needed (I
don't think) since I already have a top/bottom ground plane.
    You are probably getting tStop errors because your tStop polygon overlaps
    the silkscreen (tPlace). Just approve those errors. BTW, your tStop polygon
    should cover the entire metal portion of the regulator's body, not just the
    tab.
  • rossw
    rossw over 10 years ago in reply to autodeskguest
    David Pollum wrote on Mon, 09 November 2015 20:18
    overlaps the silkscreen (tPlace). Just approve those errors. BTW, your
    tStop polygon should cover the entire metal portion of the regulator's
    body, not just the tab.
    Thanks David. I also read that I should use vias to connect the top ground
    plane to the bottom for better heat transfer. If so, do I need to turn off
    the thermal mask on them? Anything else I should do to make this heat sink
    work?
    autodeskguest over 10 years ago in reply to rossw
    RossW wrote on Mon, 09 November 2015 22:05
    ground plane to the bottom for better heat transfer. If so, do I need to
    turn off the thermal mask on them? Anything else I should do to make this
    heat sink work?
    You don't want thermals on because you want maximum heat flow from top to
    bottom. You do want to have the vias' metal exposed, so you want tStop and
    bStop for the vias. BTW the Arduino Duemilanove uses 24mil vias around its
    5 volt SMD regulator to connect its top copper polygon to its bottom copper
    polygon.
  • rossw
    Thanks David. I know I can turn the Thermals off on a via with the 'i'
    tool, but how do I change the tStop & bStop solder masks on a via? I was
    planning on drawing a polygon in both the tStop & bStop layers around the
    whole regulator - will that work?
    RossW wrote on Tue, 10 November 2015 20:16
    In the board editor go to Design Rules, Masks and look at the "limit" box.
    This is normally set to 0. That means that all vias will have a tStop
    solder mask. So your idea will work.
