EAGLE User Support (English) Code help please. Arduino Uno / velleman VMA05 controlling relays and rgb light for external 12V systems in vehicle.
  • Subscribers 179 subscribers
  • Views 455 views
Hi
I have been desperatly trying to write a code that i felt would be
simple but i am unable to finish it.
I want to control the VMA05 relays with individual buttons in a toggle
fashion with momentane pushbuttons. Six relays and six buttons. i also
want a specific behavior of several RGB lights to indicate open or
closed relay by switching from green to blue when activated and back
when deactivated by a second press.
i have been trying several variants of code just stumbling around but i
want the setup to be closely like this (in assumed function) I
apreachiate any and all help, a dream would be if someone really smart
could fix this code for me. The arduino board will be used to control
systems for a vehicle used in Swedish volonteer mountain rescue
situations as well as other live scenarios (which due to the lack of
budget explains the use of arduino)
const int BTN1 =7;
int press1 =0;
const int BTN2 = 6;
int press2 =0;
const int BTN3 = 5;
int press3 =0;
const int BTN4 = 4;
int press4 =0;
const int BTN5 = 3;
int press5 =0;
const int BTN6 = 2;
int press6 =0;
int relay1 =8;
int relay2 =9;
int relay3 =10;
int relay4 =11;
int relay5 =12;
int relay6 =13;
void setup()
  pinMode(8, OUTPUT);
  pinMode(9, OUTPUT);
  pinMode(10, OUTPUT);
  pinMode(11, OUTPUT);
  pinMode(12, OUTPUT);
  pinMode(13, OUTPUT);
  pinMode(7, INPUT);
  pinMode(6, INPUT);
  pinMode(5, INPUT);
  pinMode(4, INPUT);
  pinMode(3, INPUT);
  pinMode(2, INPUT);
void loop()
  press1 = digitalRead(BTN1);
  if (press1 == HIGH && relay1 == LOW )
   (relay1, HIGH);
  }else
   (relay1, LOW);
    press2 = digitalRead(BTN2);
  if (press2 == HIGH && relay2 == LOW )
   (relay2, HIGH);
  }else
   (relay2, LOW);
    press3 = digitalRead(BTN3);
  if (press3 == HIGH && relay3 == LOW )
   (relay3, HIGH);
  }else
   (relay3, LOW);
    press4 = digitalRead(BTN4);
  if (press4 == HIGH && relay4 == LOW )
   (relay4, HIGH);
  }else
   (relay4, LOW);
    press5 = digitalRead(BTN5);
  if (press5 == HIGH && relay5 == LOW )
   (relay5, HIGH);
  }else
   (relay5, LOW);
    press6 = digitalRead(BTN6);
  if (press6 == HIGH && relay6 == LOW )
   (relay6, HIGH);
  }else
   (relay6, LOW);
http://www.element14.com/community/message/164791
    Hi
    Looking at your code it would appear that it is working, but not as you
    expected, because the program is looping so fast that pressing the
    button will result in an on statement and an off statement almost
    immediately.
    Take a look at the following code, taking into account the use of the
    "previous" variable and incorporate this into your design.
    https://www.arduino.cc/en/Tutorial/Switch
    You could basically replicate this code 6 times and add a number to
    these variables.
    Does this make sense?
    Paul
    http://www.element14.com/community/message/164827
    autodeskguest over 10 years ago in reply to autodeskguest
    Hello and thankyou for your reply
    I actually found this specific tutorial and gave it a try. I failed
    however, i tried this without result.
    I dont know where to add the relay HIGH... As i want a on off toggle
    effect with the same momentane button i am at a loss. So you see my
    mistake?
    int inPin1 = 2;
    int inPin2 = 3;
    int inPin3 = 4;
    int inPin4 = 5;
    int outPin1 = 13;
    int outPin2 = 12;
    int outPin3 = 11;
    int outPin4 = 10;
    int state = HIGH;      // the current state of the output pin
    int reading1;
    int reading2;
    int reading3;
    int reading4;          // the current reading from the input pin
    int previous = LOW;    // the previous reading from the input pin
    // the follow variables are long's because the time, measured in
    miliseconds,
    // will quickly become a bigger number than can be stored in an int.
    long time = 0;         // the last time the output pin was toggled
    long debounce = 200;   // the debounce time, increase if the output
    flickers
    void setup()
      pinMode(inPin1, INPUT);
      pinMode(inPin2, INPUT);
      pinMode(inPin3, INPUT);
      pinMode(inPin4, INPUT);
      pinMode(outPin1, OUTPUT);
      pinMode(outPin2, OUTPUT);
      pinMode(outPin3, OUTPUT);
      pinMode(outPin4, OUTPUT);
    void loop()
      reading1 = digitalRead(inPin1);
      // if the input just went from LOW and HIGH and we've waited long
    enough
      // to ignore any noise on the circuit, toggle the output pin and
    remember
      // the time
      if (reading1 == HIGH && previous == LOW && millis() - time > debounce)
        if (state == HIGH)
          state = LOW;
        else
          state = HIGH;
        time = millis();
      reading2 = digitalRead(inPin2);
      if (reading2 == HIGH && previous == LOW && millis() - time > debounce)
        if (state == HIGH)
          state = LOW;
        else
          state = HIGH;
        time = millis();
      {  reading3 = digitalRead(inPin3);
      if (reading3 == HIGH && previous == LOW && millis() - time > debounce)
        if (state == HIGH)
          state = LOW;
        else
          state = HIGH;
        time = millis();
      {reading4 = digitalRead(inPin4);
      if (reading4 == HIGH && previous == LOW && millis() - time > debounce)
        if (state == HIGH)
          state = LOW;
        else
          state = HIGH;
        time = millis();
      digitalWrite(outPin1, state);
      digitalWrite(outPin2, state);
      digitalWrite(outPin3, state);
      digitalWrite(outPin4, state);
      previous = reading1;
      previous = reading2;
      previous = reading3;
      previous = reading4;
    http://www.element14.com/community/message/164865
    mistake?
    One of your mistakes is that you've posted this in the wrong place. This
    is a discussion group for the Cadsoft Eagle PCB design tool. You'd get
    better answers in a programming related forum.
    That said, if you want a toggle action, you must ignore the button being
    held and only toggle when it's first pressed. The basic code will be:
    if ( input==HIGH && old_input==LOW )     // Only act on leading edges
        output = ! output;          // toggle the output
        old_input = input;          // remember the state for edge detect
    I'll leave the incorporation of this principle, including the fixing of
    the glaring bug, as an exercise for the reader.
    Hi
    Oh sorry i did not realize, found my way here through some weird arduino
    google search and gave it a try.
    thank you for your help but as i am not a programmer this is a bit
    beyond me and since i need to make the code work just once i dont feel i
    have the time to learn programming for this one instance, but i greatly
    appreciate your efforts!
    I will try to make sense of this and keep searching for a more
    programming related page.
    Thankyou //Thor
    http://www.element14.com/community/message/165253
    You have posted this in on an ENTIRELY appropriate website. Just in the
    wrong area.
    I will ask  or  to move this topic to a more appropriate area.
    Maybe Arduino (http://www.element14.com/community/groups/arduino).
    From there we can help you further.
    http://www.element14.com/community/message/165315
