EAGLE User Support (English) Is there a quicker way of connecting component pint to the net?
  • Subscribers 187 subscribers
  • Views 236 views
autodeskguest over 8 years ago
After placing the component a small piece of Net must be drawn from
each of the pins before being able to assign a name to that net. That
can take quite a long time if a component has many pins.
Is there some quicker way of doing the same? For example, in Proteus
one can draw only the first net and then just double click on the ends
of other pins to draw the nets of the same size as the first one.
I am referring to drawing the short green 'wires' as in this video:
https://youtu.be/6ikZHzEYQcQ
This is how it can be done in Proteus by double-click:
https://youtu.be/12QCT-lLX3E
The double-click works exactly the same even when there isn't a bus,
the function duplicates the length of the last drawn net.
I am interested in the best way for Eagle 6.2
Let There Be Light
Custom LED driveri prema specifikacijama
http://tinyurl.com/customleddriver
Chupo
