EAGLE User Support (English) Looking for IR Receiver
  • Subscribers 189 subscribers
  • Views 3013 views
  • vishay
  • ir receiver
  • tsop 382
foxeater
foxeater over 8 years ago
Hey Gang,
Couldn't find any IR sensors.  Looking for TSOP 382 or equivalent.  Not in the Vishay parts library either.
Thanks oodles.
  • foxeater
    foxeater over 8 years ago in reply to autodeskguest
    You're a champ!  Thanks for the help!  I have a new question posted about the lbr file for the ESP8266.
    autodeskguest over 8 years ago in reply to foxeater
    On 9/11/2017 9:38 a.m., Regular Guy wrote:
    Suppose I should also mention I'm in the EAGLE software trying to find this, too.
    https://www.element14.com/community/message/230973
    Hi
    Sparkfun have a library that contains what you need.
    https://github.com/sparkfun/SparkFun-Eagle-Libraries/blob/master/SparkFun-Sensors.lbr
    It a BRM-2508
    http://p.globalsources.com/IMAGES/PDT/SPEC/138/K1040521138.pdf
    Once you have it, verify that it is correct for your use.
    HTH
    Warren
    ... use NNTP://news.cadsoft.de and a functional news reader like
    Thunderbird!
    This email has been checked for viruses by Avast antivirus software.
    https://www.avast.com/antivirus
    Am 08.11.2017 um 21:38 schrieb Regular Guy:
    Check the telefunken.lbr
    If you had used the search in the ADD and written TSOP* the you would
    find the same.
    Joern Paschedag
  • fmilburn
    fmilburn over 8 years ago in reply to foxeater
    I don't use Eagle, but the TSOP382xx devices are thru hole 0.1" (2.54mm) pitch with 3 pins.  If I understand your question correctly just place a regular 0.1" header with 3 pads where you need it on the PCB.
    Frank
  • foxeater
