EAGLE User Support (English) Alternative symbols for easy rotation
  • Replies 11 replies
  • Subscribers 189 subscribers
  • Views 2195 views
When placing a common library part such as a resistor or capacitor it's
often necessary to rotate it to fit in with how you are drawing a certain
part of your schematic. For any one device, library symbols can currently
only be drawn in a single rotational position so when you then rotate the
part your text is now no longer how you would like it and you are required
to smash the device and manually replace all the text in the right
positions and orientations. This is okay for a handful of components but
not good for a large design. It's fine for a hobbyist just throwing
together small projects for their own use but as a professional design
engineer, when I present clients with schematics I have drawn they need to
look professional and this is causing additional work to achieve this.
It would be nice if several versions of a symbol (up to 4) could be
provided which would automatically be cycled through upon rotate if they
were available. This would mean we could create nice sets of symbols in our
libraries and rotate away to our hearts content safe in the knowledge that
we wouldn't be building up a mountain of smash and reposition work down the
line.
A quick fix I tried for this was to have -H and -V variants of resistors,
capacitors etc but this just became a pain in the BOM! (pun intended!)
Many thanks,
Rachael
  • rachaelp
    rachaelp over 10 years ago in reply to e14 Contributor
    Hi Jay,
    It seems like you have another perfectly valid use for this feature which is different from my use case :-)
    To answer your final point, it wouldn't necessarily be tied in any way to actual rotation, it could use the different symbol variants to cycle through symbols which were drawn at different rotations so no need for any involvement of the separate rotate command. It could maybe have an enhancement such that a flag set in the library part linked it to rotation which would then enable the schematic to be changed more easily in future if the orientation needed to be changed.
    I do believe that with this approach, the need for smash and reposition in your first paragraph could be significantly reduced with an appropriately designed library which matches your style guides, especially as the schematic must use a 0.1" grid so all other text can be placed at any alternative off grid locations within the library. It'll likely never be 100% and you'll still have to smash and tidy up some parts but I think a lot should just go down without needing any fettling.
    Best Regards,
    Rachael
    Hi All,
    Since the last thread went completely off the rails, I'd like to respond to the original post.
    I routinely use smash and rotate, change font, change size, etc., on all the parts in a design until I have it looking professional.  Not because my readers are stupid, but because I'm a professional and I take pride in my work.  Our company has strict rules for the size of text, fonts, line weights, etc.  At the library level, we use a script to add standard name and value texts to layers; we don't bother trying to position them nicely because we always align them to the grid in the schematic when we finalize the schematic.
    Now, I WOULD like to cycle between alternate symbols for supporting DeMorgan equivalents because authoring schematics using positive logic conventions DRASTICALLY reduces logic errors and makes them much easier to verify.  If I have two active low signals and I want the active high output signal to be true when either input is true, the symbol would be an OR body with a bubble at each input and none on the output.  The implementation would be a NAND gate.  So a NAND gate would have two symbols, one with an AND body and a bubble at the output, another with an OR body and a bubble on each input.  Same gate, two different symbols.  I tried making a DeMorgan version of my logic library, but don't like the idea of maintaining each part in two libraries -- it's likely a change might be made to one and not the other.
    So while I agree that it would be nice to have different symbols (for whatever purpose), I wouldn't want those alternate symbols to necessarily be tied to the rotation.  But if someone else wanted to build their library that way, they certainly could; whatever mechanism selected the alternate symbol would have to be performed in addition to the rotation, but that would be less work than smashing and realigning text.
    Jay
    autodeskguest over 10 years ago in reply to autodeskguest
    On 12/8/2015 6:16 AM, Morten Leikvoll wrote:
    Ok, this is growing out of proportions, so Im gonna end this short.
    Yes, you are right on many of your statements (also regarding my attitude)
    The reason why I have this attitude regarding vertical reading is kinda
    related to the tool we are actually discussing. We are discussing Ealge.
    I doubt any high requirement space/safety would even allow Eagle as a
    design tool for their gear. I may be wrong, but I think they will have
    their standards to work along, and alignment of text would be very low
    down on that list of need-to-have featurs. Eagle would fail early here.
    Eagle has too many issues that would not make me feel good to use in
    those high requirements products.
    Hi Morten,
    You would be very surprised at the areas where EAGLE is allowed and the
    high requirements it's used to meet. I can't name drop, but the point is
    just to say that I see value in this being added to EAGLE.
    I have sent an enhancement request to the devs on this issue. Now it's
    up to them.
    Best Regards,
    Jorge Garcia
    Morten Leikvoll wrote on Mon, 07 December 2015 03:28
    -a slave of some company rules invented by someone not even able to
    read
    schematics.
    That may be true, but it would be reality nonetheless.  Sometime
    requirements are requirements.  All-horizontal text is sometimes a
    requirement, whether you think it's silly or not.  I happen to make my
    schematics that way all the time, but that doesn't matter when a large
    corporate customer insists the consultant does it that way, or they'll get
    a different consultant.
    This really should be something Eagle could allow us to do more easily.  I
    know I'd use it heavily, whether required to do so or not.
    Quote:
    In any case, Im sure I could easily get them to accept vertical text.
    Again, sometimes it's a requirement that you don't get to negotiate if you
    want the job.
    Quote:
    And Im sure that's an easier job than to get this apparently
    inconsistant feature into Eagle.
    You seem to be misunderstanding something.  I recognize you don't think the
    feature is important, but inconsistant makes no sense.  All we're asking
    for is the ability to have alternate symbols within a single device.  These
    could then be optionally tied to specific rotation angles to make selecting
    them particularly simple.
    Right now you have to either rotate and smash parts, or make whole
    alternate devices just to get symbols in different orientations.  Both
    those make more work and give greater chance of inconsistancy.
    Quote:
    I feel bad when I read schematics where the
    refdes/value placement is unpredictable.
    Predictability makes little sense in this context.  There is nothing to
    predict when the schematic is in front of you.  If you really meant
    consistancy, then that makes little sense too.  In your system, the
    direction towards the refdes and value are inconsistant because they depend
    on how the part was rotated.  You're already not getting all refdes to the
    right, for example.  You might get that for a vertical resistor, but then
    the refdes would be above (and tilted 90 deg in addition) for a horizontal
    resistor, or maybe below and tilted the other way, depending on whether the
    stock part was rotated 90 or 27 deg.
    With the proposed system, you could have refdes and values to the right for
    vertical resistors and refdes above and value below for horizontal
    resistors, for example.  That would be more consistant since each would be
    pre-defined as separate symbols for their orientation, so less chance of
    differences across the schematic.
    Quote:
    Actually I dont
    mind some sloppyness on prototypes, it may help me identlfy weaknesses
    in both the design, and production process.
    Wait, you're actually saying manufacturing errors are good for your
    prototyping process!?  Sorry, but that's just silly.  Designing a circuit
    so that any resistor can be replaced by a capacitor or any other component
    that comes in the same package makes absolutely no sense, and is totally
    impractical anyway.  This is not designing to part tolerance ranges, but
    basically random replacement of parts.
    Playing along for a little, let's consider how this is supposed to work.
    Your tech installed a SOT-23 zener where you specified a SOT-23 NPN
    transistor.  Your circuit doesn't work and you trace it down to this
    manufacturing error.  What are you going to do about it?  Redesign the
    circuit to be tolerant of either a zener or transistor in that spot?
    Surely you must see how silly that is.  And next time it could be a PNP
    instead of a NPN, or a MOSFET.
    Quote:
    If I worked
    for you and you asked me to do this on Eagle, we'd be having a hot
    argument about time spending and resource utilization,
    No, we wouldn't.  Certainly not for very long.
    autodeskguest over 10 years ago in reply to rachaelp
    On 07.12.2015 14:48, Rachael wrote:
    Given the first paragraph to your latest comment I expect you won't bother
    to reply, which is fine, as I said previously this is just a suggestion,
    you don't have to like it, agree to it being in Eagle or use it if it ever
    did make it in there. I can see now I'm not the only person that would like
    this but maybe I am in a minority and I don't care, it's something that
    would be helpful to me when dealing with some of my clients.
    Morten Leikvoll wrote on Mon, 07 December 2015 08:28
    For this topic, the smash function covers the vertial reading
    disabilities and I see no reason to change this in Eagle.
    No the smash function is a cludge that allows a work around. It takes time
    to smash and reposition things and risks errors being made.
    I do however see the potential for scewing up readability by placing
    the refdes/value totally wrong, or even delete them. Its a function I try
    to stay away from, although in some rare cases I may choose to use it.
    So you say smash does the job so you see no reason to change this in Eagle
    and then in your next sentence you go on to give a good reason why smash
    isn't good for this after all.
    We are all different people with different skills and habits and some
    of us work better together than others. I accept that, but if a customer
    ever threw this request at me, I would first assume he/she was either:
    -a documentation geek, demonstrating his powers
    read schematics.
    -someone unskilled at reading schematics who is comparing to something
    else he/she saw.
    Have you ever worked for large multinationals with strict procedures?
    Especially in for example the aerospace field? I'm not going to annoy them
    by pushing back and refusing to do something they require and risk not
    getting any future work from them.
    No it's really not easier, for some clients this is non-negotiable, no
    matter how stupid you think their requirements are. Why is this feature
    inconsistent?
    Yes neatness counts, but when we have different views of what's neat,
    you dont get far. I feel bad when I read schematics where the
    I agree with you and hence this feature would ensure refdes/value were all
    placed predictably.
    I prefer drawing the sch to make space for labels where they are,
    relative to the symbol.
    I assume you mean so you can label functional blocks of your design to make
    it more readable? Completely agree but off topic.
    The production attitude you mention is slightly off topic, but is
    important in production line, not that much during design. Personally I
    dont give a damn on details like that for my prototypes, at least in my
    current work environment where there is no safety risks. Actually I dont
    mind some sloppyness on prototypes, it may help me identlfy weaknesses in
    both the design, and production process. I never expect production to be
    100% correct all the time, there are lot of humans involved. But I do add
    selftests wherever I can.
    This statement make no sense. Sloppyness doesn't identify weaknesses in
    design or production, it just identifies issues caused where somebody
    couldn't be bothered to do something right. All it does is cost time/money
    to rectify these issues before you can go ahead with the more important job
    of testing out your prototypes to ensure your design was in fact correct.
    From reading your posts over the years, I know we are different people,
    but at least we have something in common, since we are both die hard
    Eagle users.
    I've not been using Eagle for nearly as long as yourself or Olin but I have
    become quite a fan of it over the last year I have been using it. I've used
    several high-end tools from the likes of Mentor Graphics and Cadence and
    while they do provide some really nice features is comes at an immense
    cost, both up front and ongoing for support. Eagle isn't as polished and it
    has its usability quirks but in most cases you can get it to do what you
    want with a little bit of patience and scripting knowhow. In other cases
    you can't, and you need a little help from the devs to provide the
    facilities to allow it to do what you need, but generally it can cater for
    many diverse requirements.
    As you said, we are all different with very differing requirements. You may
    not see the value in this but to be quite so dismissive for no reason seems
    quite unfair. You could just have ignored the post altogether if it wasn't
    something you were interested in.
    Rachael
  • rachaelp
    rachaelp over 10 years ago in reply to autodeskguest
    read schematics.
    else he/she saw.
    inconsistent?
    placed predictably.
    Eagle users.
    Rachael
    On 05.12.2015 15:17, Olin Lathrop wrote:
    Morten Leikvoll wrote on Thu, 19 November 2015 06:00
    Is vertical reading really that difficult?
    It may not be stictly speaking all that "difficult", but that's not the
    point.  It is certainly annoying and very unprofessional.  Every time you
    decrease clarity and annoy those who have to read the schematic, you
    increase the chance of someone misinterpreting it.  Even one such case out
    in the field can be more expensive than to have drawn the schematic
    properly in the first place.
    I didn't even want to reply to this imho irrelevant topic, but since its
    early morning, and my fingers need to warm up, here I go.
    I think this topic belongs in the nitpicking category. It is very hard
    to make all the different people happy, especially the few that has some
    unique preferences or minor reading disabilities. For this topic, the
    smash function covers the vertial reading disabilities and I see no
    reason to change this in Eagle. I do however see the potential for
    scewing up readability by placing the refdes/value totally wrong, or
    even delete them. Its a function I try to stay away from, although in
    Quote:
    All my schematics are a mix of H and V and nobody I met ever had
    problems interpreting that.
    Being correct is only a necessary but not sufficient requirement for a good
    schematic.  It's not about whether in the end someone was able to correctly
    interpret your schematic, but how easily, with little chance of error, and
    without the feeling the designer just threw slop at them.  Don't
    underestimate the latter.
    We are all different pepople with different skills and habits and some
    -a slave of some company rules invented by someone not even able to read
    schematics.
    else he/she saw.
    Neatness counts, A LOT.  Your production tech, field tech, or customer,
    might not complain, but what attitude did they have when dealing with your
    schematics?  Maybe they weren't even aware of it, but the "eh, who cares"
    attitude exhibited by your schematic probably caused a little of the same
    in them.  Eh, that solder joint is probably good, I'm not going to bother
    to check with the jewler's loupe like I usually do. Eh, that cap fell on
    the floor where I might have stepped on it, it's probably not cracked, good
    enough, not worth my getting out of this chair to get a new one.  And so on
    it goes.
    refdes/value placement is unpredictable. I prefer drawing the sch to
    make space for labels where they are, relative to the symbol.
    in both the design, and production process. I never expect production to
    be 100% correct all the time, there are lot of humans involved. But I do
    add selftests wherever I can.
    When you give someone sloppy work, you set the tone and give them
    permission to do the same.  Or, if you're working for them, they may decide
    they like the other engineer's work better, even if they aren't even
    concious of why.
    I can tell you for sure that if you worked for me, you'd be making all your
    text horizontal.  And if I actually had to say something to you to make
    that happen, I probably wouldn't tell you this, but your lack of
    professional pride in your work would be something in the back of my mind
    when deciding who to assign to what task.
    You make me smile and think all the thoughts I listed above. If I worked
    argument about time spending and resource utilization, and maybe end up
    having dark clouds hanging over both our heads. If eagle had this as an
    option already, I would still think the thoughts and not care.
    If you were working for me, I think you'd do good production quality
    control, at least if you behave toward people less skilled than you image
    Eagle users.
    rachaelp wrote on Wed, 18 November 2015 09:41
    resistors, capacitors etc
    That's what I do to, sometimes -L -R -U -D and the like.  My BOM system
    undestands the -XX naming of devices and realizes that all the variants are
    in fact the same device.
    Actually, it's not that quick a fix.  It takes more time to make library
    parts and keep all the -XX variants of each device up to date.  The extra
    work is mostly in the device editor since the package is the same, and the
    symbol is what you want different between variants in the first place.
    I find writing the commands to set up a device in a script file helps.
    That allows incremental tweaking to get it right, then usually small
    modifications are required to run the same script in the other -XX variants
    of what are otherwise the same device.  Yes this is a pain, but it is
    unfortunately the only alternative that Eagle has given us.
    I'm a little worried about selecting the different symbols only by
    specifying orientation.  There needs to be some mechanism to explicitly
    select a symbol regardless of orientation.  I do like the idea of being
    able to tie different symbols to different rotations as default, which then
    allows you to cycle thru them with the right mouse button instead of
    actually doing the rotation.  That would probbaly cover 99% of the use
    cases.  Some explicit selection still needs to be possible, but doesn't
    need to be as quick as a single mouse click.  If the part is smashed, then
    the symbol selection by rotation must be shut off.
    In any case, I've wished for some way of having alternate symbols per
    device also, for the same reason you state.
    it goes.
    concious of why.
    No it's not difficult and it's not a question if not being able to
    interpret them, but I have dealt with large companies who have very strict
    style guides for schematics though and this sort of thing becomes an issue.
    If it's not a problem for you then fine, for me this is something I would
    find useful.
    It's only a suggestion, hence it's in the eagle.suggest forum, so if you
    don't like it feel free to ignore it. I'm pretty sure the devs will only
    implement things that enough people have asked for to make it worth their
    while anyway so if it's just me that thinks this would be useful then I'm
    sure they won't waste their time implementing it.
