    • Avnet Boards Community
EAGLE User Support (English) Managing Fitted / Not FItted components
  • Subscribers 176 subscribers
  • Views 1068 views
When doing a design I often find I need to have parts that are fitted or
not fitted so I can either make a decision on how things should be set
depending upon evaluation of a design on the bench or it might be to help
support having different variants of the same design for different
products. As far as I can see the only way to identify a part as Not Fitted
at the moment is to change it's value to NP or NOFIT so that when you
generate a BOM you can discard all the not populated values. The problem
here is you lose the value so you need to keep a track of what it should be
elsewhere in case you want to reinstate it at some point. It's also a bit
fiddly and with a large design could take a lot of additional effort to
manage.
In other tools I have used I have set things up so I can specify a "Fitted"
property (yep we can do this in Eagle just fine too). You can then have a
right click menu item which for a particular part will allow you to toggle
it's fitted state. If not fitted there would be a cross placed through the
part to indicate that it was not fitted on the schematic and the property
would be automatically set. The BOM generation would then be such that it
would output the BOM containing only the fitted parts and then optionally a
separate not fitted BOM so as to easily allow further checks on a build in
manufacturing. This way you can very easily manage fitted / Not Fitted
parts, you don't lose the intended value information and you get a
correctly generated BOM and it should work well when trying to manage
multiple variants of a board.
Many thanks,
Rachael
    Am 18.11.2015 um 16:30 schrieb Rachael:
    manage.
    Many thanks,
    Rachael
    Hello Rachael,
    it seems that your are describing the "Variant" command of eagle image
    Help-> Variant
    HTH
    Werner
    Werner Harbrecht wrote on Wed, 18 November 2015 16:53
    Hello Rachael,
    Help-> Variant
    HTH
    Werner
    Hi Werner,
    Yes this is actually very close! This is almost what I am trying to do
    except I would like to be able to extend it to be able to mark parts as
    fitted or not without having to specify a separate variant and switch to it
    and without having to go into the variant dialog to be able to mark
    something as fitted or not. I.e. I would like to be able to right click on
    a part in the schematic and mark it as fitted or not fitted.
    Maybe if the "default" variant allowed the selection of fitted / not fitted
    then this would then be easy to add into the context menu for individual
    components?
    I guess the down side of this approach is it may be too easy to
    accidentally mark a part or parts (combined with the group command) as not
    fitted but hopefully it would be quite obvious what had happened and could
    easily be undone. Alternatively the "Mark as Fitted" or its converse "Mark
    as Not Fitted" could be on another menu (e.g. Edit) so you group select the
    parts of interest and then go to the menu.
    Many thanks,
    Rachael
    Hi Werner,
    Actually looking at this some more, as soon as I create myself a 'Default'
    variant I can then easily use the variant command to make the changes. I
    guess the creation of any needed menu items is then down to writing an
    appropriate bit of ULP to build them which is currently not my strong
    point.... It would be nice as an out of the box feature of Eagle to be able
    to do this though so I think it's still a valid feature request but I guess
    there are a lot of requests and finite developer resource!
    Thanks for your help in pointing me in the right direction on this.
    Best Regards,
    Rachael
  • dukepro
    dukepro over 9 years ago in reply to autodeskguest
    Good afternoon, Rachel,
    A ULP program can not modify anything.  However, it can be used to
    collect a series of script commands into a string,  then exit the ulp
    with the string as the single argument:
        string cmds;
        cmds = "value R1 10k;\n";
        cmds += "value R2 22k;\n";
        exit(cmds);
    As a side note, one can use any method to produce a file containing
    script commands.  ULP is just one method.
        - Chuck
    On 11/18/2015 12:22 PM, Rachael wrote:
    Hi Werner,
    Best Regards,
    Rachael
    82823.att1.html.zip
    autodeskguest over 9 years ago in reply to dukepro
    Hi Chuck,
    Thanks for the tips! I've not looked at ULP or any other scripting in Eagle
    until today but I have done scripting in other tools so hopefully I should
    be able to pick things up relatively easily here, it's good to know some of
    the limitations of ULP though! I've just finished a project I was working
    on for a client so I should have a little time to investigate and have a
    little fun trying to get things working how I would like.
    Many thanks,
    Rachael
  • Joop14
    Joop14 over 9 years ago
    We create an attribute for the device with the content "NM" (non mount) if it's not to be mounted/placed.
    It's very easy to write an ULP or modify an existing one that creates/exports a BOM that ignores components with this attribute value set.
