EAGLE User Support (English) eagle software for raspberry pi 2
  • Views 568 views
keithhampton42@gmail.com
keithhampton42@gmail.com over 8 years ago
I have a raspberry pi 2, and I need to design a sechmatic with it.  I can only fine 64 bit versions of Eagle to download.  is there a 32 bit that I can download?  if not can you suggest a different free package?  thanks in advance,
    autodeskguest over 8 years ago in reply to rachaelp
    On 14/07/18 20:02, rachaelp wrote:
    Hi Keith,
    Unfortunately EAGLE is compiled for Intel/AMD 64-bit processors only so as the Raspberry Pi is ARM based it is not possible to run EAGLE. I don't know of other ECAD packages which are available for ARM, the only possibility I can think of is KiCAD which is open source so maybe somebody has built an ARM version but I'm not sure that's too likely to be honest.
    There is a KiCAD package for Raspbian - that's probably your best bet,
    although it may not be very up to date.
  • rachaelp
    rachaelp over 8 years ago
    Hi Keith,
    Best Regards,
    Rachael
