Forum Have a question about CadSoft EAGLE?  Ask our Expert, Richard! (Archive)
  • Replies 1129 replies
  • Subscribers 245 subscribers
  • Views 51209 views
  • eagle
  • expert
  • richard_hammerl
  • cadsoft
nlarson
nlarson over 16 years ago
This thread is now locked - but you can still ask Richard by posting your questions here.  If you'd rather browse other member's questions you can read the CadSoft EAGLE Forums for past questions and answers. Enjoy!
Browse past Q&A help on anything technical relating to CadSoft EAGLE!
Richard Hammerl
Richard is an engineer with 16 years experience in EAGLE customer support and is waiting for your questions.
  • igalloway
    igalloway over 14 years ago in reply to Richard_H
    Castillated edges could be two things...
    - series of (unplated) drill holes closely spaced  in a row so that
    the board breaks off there.
    -  I/O signals and power for the entire board are routed the
    equivalent of large vias (plated drill holes) cut in half right at the
    edge of the board, that are then used to make the board like a
    "surface mount" assembly. Sometimes found on things like a smt radio
    module.
  • Richard_H
    Richard_H over 14 years ago in reply to e14 Contributor
    Hi Bayrak,
    the link you posted in your message works for me.....
    Please try it again.
    Richard
  • Richard_H
    Hi Joe,
    I am sorry, but I am not familiar with the expression "Castellated edges". Is this something like passer marks which we have in our marks.lbr?
    Richard
    Hi i want to have a look at the eagleUp, 3D visualisation toolkit, but the eagleUp 4.2.zip link is not working. Is ther eanother URL for this? Thank you.
    Richard,
    Do you know of any library that contains castellations for PCB's ?      I am making a surface mount PCB that contains castellated edges for pads and wanted to check to see if they exist  before I make them myself.
    Joe A.
    e14 Contributor over 14 years ago in reply to Richard_H
    Thanks again, Richard.
    Robert
  • Richard_H
    Hi Denica,
    there is an interface which connects EAGLE with B2Spice. See
    http://www.cadsoft.de/services/simulation and
    http://www.beigebag.com/eagle.htm for further information.
    Richard
    Hi Richard Hammerl
    I want to ask how to make a simulation with Eagle ?
    Тhank you
  • Richard_H
    Hi Robert,
    the flash drive you are using.... how is it mounted? Does it have a drive letter and can you access it with full rights, for example with the Explorer or an other application? Have you adjusted the path settings in the EAGLE Control Panel?
    Richard
    Thanks Richard,
    That really threw me for a loop, I've been using Eagle for years wiring my sch. with the wire tool on the 'net' layer!
    One more thing, I just went to a new machine in Windows 7. I Ioaded my files from my old computer onto a flash drive but can't seem to get them to show up on the control panel. I loaded the files directly into program files(x86) the 32 bit version and the path looks right but they aren't there when i bring up Eagle?
    Thanks again for you assistance.
    Robert
