Forum where is the layer 50?
  • Subscribers 189 subscribers
  • Views 548 views
huayuliang
huayuliang over 16 years ago
Hi~
same as question, I read the manual, there is not this layer, but I saw this layer in the project file that I download from net.
where is it now ? is it be canceled?
is it means that I must use layer 20 dimesion to import the dxf ?
thanks
best reguards!
  • huayuliang
    Thanks these reply.
    can only use command LAYER  50  DXF; done this.
    best Regards!
  • Richard_H
    Richard_H over 16 years ago in reply to e14 Contributor
    If the layer does not exist yet, you have to use the Layer command with number and name, like in
    LAYER  50  DXF;
    LAYER 50 without a layer name can be used to active the hidden layer. But this implies that this layer has already been set up .
    Some layers will only exist when you explicitly start to use them.
    If you type in "Layer 50;" into the command box, it'll be generated for you. The layer will also come into life if you have a ULP that uses it.
