Forum about EAGLE
  • Subscribers 187 subscribers
  • Views 377 views
about EAGLE
good mornig
What does the phrase: grip in mm or ich, up to 255 drawing layers.
thanks you very much.
regards
  • Richard_H
    Richard_H over 16 years ago
    David,
    grid in mm or inches  says that the grid settings in the schematic/layout/library editor can be chosen in inches or if you prefer in millimetres.
    up to 255 drawing layers  ---  EAGLE distinguishes between signal layers and drawing layers. The professional edition, for example, can have a maximum of 16 signal layers. And there are additional "non-electrical" layers, like some for the silk screen on the board or for solder stop mask and so on. There are some pre-defined drawing layers and there are free layers that can be used for any purpose in your drawing.  The maximum number of all these layers is 255.
    HTH
    Richard
