Forum Harwin Connectors
  • Subscribers 189 subscribers
  • Views 574 views
Harwin Connectors
Hi, I work on fingerprint reader and connection of module is by Harwn connectors. I need the M50-3151042 Harwin Connector library files. Does anyone work on it ?
  • huayuliang
    huayuliang over 16 years ago in reply to e14 Contributor
    sorry, here is the single device package's library.
    M50-315XXXX.lbr.zip
    e14 Contributor over 16 years ago in reply to huayuliang
    Thanks for reply. I've never draw library before but i will try it =))
    Thanks for helping...
  • huayuliang
    Why not draw it yourself? it is so easy, only use default grid size and half grid size....
    you are lucky, I just have this. but if none have it ......
    here is a scr file for packege of M50-31510XXX that export from my old project's library. just run in you library editor, you need draw the symble yourself and combine to a device.
    M50-31510XX.scr.zip
