Forum Putting a TIP transistor into Eagle?
  • Views 1091 views
This is the first time I've ever used a PCB design software (though I've done plenty on breadboards), and I went through the Eagle library and I can't find the part for the transistor TIP120G (here's the datasheet: http://pdf1.alldatasheet.net/datasheet-pdf/view/175430/ONSEMI/TIP120G.html).
Is there something with the same pin spacing I can use?
  • huayuliang
    huayuliang over 16 years ago
    It is a TO-220 package transistor, you can use other transistor that with same package.
    for example, the TIP122 in tansistor-npn.lbr, but it is horizontal package.
    if you need other, you can make device your self, there is many many standard pakage in ref-packages.lbr.
