Forum How to use the character ">" in command line?
  • Subscribers 187 subscribers
  • Views 427 views
Michael
Michael over 15 years ago
Hi Rechard,
                 I learned that the character ">" in command line represents a right-click of mouse, but when I enter (> 1 2) on the command line of schematic editor (a part is located on coordinate (1 2)). The software prompt an error "Point not expected". If ">" is right-click, how come the result from command line is not the same as right-click on that coordinate with mouse? I guess this character should be used with a command such as GROUP and MOVE, am I right? For example: Group .......; MOVE (> X Y) (X Y);
  • Richard_H
    Richard_H over 15 years ago
    Hi Michael,
    coordinated have to be used with an active command. The right mouse click can be used for moving a group of objects, for example. The syntax
      GROUP ALL;  MOVE  (> 0 0) (1 1);
    is correct then.
    By the way: In case you select a group with Ctrl+ right mouse click you have to write:
    GROUP ALL;  MOVE  (C> 0 0) (1 1);
    Richard
