Forum Looking for a TSOP 54 package
  • Views 692 views
I have been doing some searching both within the Eagle libraries that I have and general searches of the Internet and haven't had any luck finding this package. Any help finding one would be appreciated.
  • Richard_H
    Richard_H over 15 years ago in reply to e14 Contributor
    I looked in the current 5.10.0 version for the package. I extracted the two packaged definitions from the lbrs there and attach it here as a script file. You can run it within a library window with the SCRIPT command.  Two packages will be created then.
    Hope this helps.
    Richard
    tsop54.scr
    Edit 'TSOP54-400.pac';
    Description '\
    <b>54-Pin Plastic TSOP</b> (400 mil)<p>\n\
    Source: http://download.micron.com/pdf/datasheets/dram/sdram/256MSDRAM.pdf';
    Layer 1;
    Smd '1' 0.9 0.4 -0 R90 (-10.4 -5.68);
    Layer 51;
    Rect R90 (-10.8 -5.6675) (-10 -5.2925);
    Layer 1;
    Smd '2' 0.9 0.4 -0 R90 (-9.6 -5.68);
    Layer 51;
    Rect R90 (-10 -5.6675) (-9.2 -5.2925);
    Layer 1;
    Smd '3' 0.9 0.4 -0 R90 (-8.8 -5.68);
    Layer 51;
    Rect R90 (-9.2 -5.6675) (-8.4 -5.2925);
    Layer 1;
    Smd '4' 0.9 0.4 -0 R90 (-8 -5.68);
    Layer 51;
    Rect R90 (-8.4 -5.6675) (-7.6 -5.2925);
    Layer 1;
    Smd '5' 0.9 0.4 -0 R90 (-7.2 -5.68);
    Layer 51;
    Rect R90 (-7.6 -5.6675) (-6.8 -5.2925);
    Layer 1;
    Smd '6' 0.9 0.4 -0 R90 (-6.4 -5.68);
    Layer 51;
    Rect R90 (-6.8 -5.6675) (-6 -5.2925);
    Layer 1;
    Smd '7' 0.9 0.4 -0 R90 (-5.6 -5.68);
    Layer 51;
    Rect R90 (-6 -5.6675) (-5.2 -5.2925);
    Layer 1;
    Smd '8' 0.9 0.4 -0 R90 (-4.8 -5.68);
    Layer 51;
    Rect R90 (-5.2 -5.6675) (-4.4 -5.2925);
    Layer 1;
    Smd '9' 0.9 0.4 -0 R90 (-4 -5.68);
    Layer 51;
    Rect R90 (-4.4 -5.6675) (-3.6 -5.2925);
    Layer 1;
    Smd '10' 0.9 0.4 -0 R90 (-3.2 -5.68);
    Layer 51;
    Rect R90 (-3.6 -5.6675) (-2.8 -5.2925);
    Layer 1;
    Smd '11' 0.9 0.4 -0 R90 (-2.4 -5.68);
    Layer 51;
    Rect R90 (-2.8 -5.6675) (-2 -5.2925);
    Layer 1;
    Smd '12' 0.9 0.4 -0 R90 (-1.6 -5.68);
    Layer 51;
    Rect R90 (-2 -5.6675) (-1.2 -5.2925);
    Layer 1;
    Smd '13' 0.9 0.4 -0 R90 (-0.8 -5.68);
    Layer 51;
    Rect R90 (-1.2 -5.6675) (-0.4 -5.2925);
    Layer 1;
    Smd '14' 0.9 0.4 -0 R90 (0 -5.68);
    Layer 51;
    Rect R90 (-0.4 -5.6675) (0.4 -5.2925);
    Layer 1;
    Smd '15' 0.9 0.4 -0 R90 (0.8 -5.68);
    Layer 51;
    Rect R90 (0.4 -5.6675) (1.2 -5.2925);
    Layer 1;
    Smd '16' 0.9 0.4 -0 R90 (1.6 -5.68);
    Layer 51;
    Rect R90 (1.2 -5.6675) (2 -5.2925);
    Layer 1;
    Smd '17' 0.9 0.4 -0 R90 (2.4 -5.68);
    Layer 51;
    Rect R90 (2 -5.6675) (2.8 -5.2925);
    Layer 1;
    Smd '18' 0.9 0.4 -0 R90 (3.2 -5.68);
    Layer 51;
    Rect R90 (2.8 -5.6675) (3.6 -5.2925);
    Layer 1;
    Smd '19' 0.9 0.4 -0 R90 (4 -5.68);
    Layer 51;
    Rect R90 (3.6 -5.6675) (4.4 -5.2925);
    Layer 1;
    Smd '20' 0.9 0.4 -0 R90 (4.8 -5.68);
    Layer 51;
    Rect R90 (4.4 -5.6675) (5.2 -5.2925);
    Layer 1;
    Smd '21' 0.9 0.4 -0 R90 (5.6 -5.68);
    Layer 51;
    Rect R90 (5.2 -5.6675) (6 -5.2925);
    Layer 1;
    Smd '22' 0.9 0.4 -0 R90 (6.4 -5.68);
    Layer 51;
    Rect R90 (6 -5.6675) (6.8 -5.2925);
    Layer 1;
    Smd '23' 0.9 0.4 -0 R90 (7.2 -5.68);
    Layer 51;
    Rect R90 (6.8 -5.6675) (7.6 -5.2925);
    Layer 1;
    Smd '24' 0.9 0.4 -0 R90 (8 -5.68);
    Layer 51;
    Rect R90 (7.6 -5.6675) (8.4 -5.2925);
    Layer 1;
    Smd '25' 0.9 0.4 -0 R90 (8.8 -5.68);
    Layer 51;
    Rect R90 (8.4 -5.6675) (9.2 -5.2925);
    Layer 1;
    Smd '26' 0.9 0.4 -0 R90 (9.6 -5.68);
    Layer 51;
    Rect R90 (9.2 -5.6675) (10 -5.2925);
    Layer 1;
    Smd '27' 0.9 0.4 -0 R90 (10.4 -5.68);
    Layer 51;
    Rect R90 (10 -5.6675) (10.8 -5.2925);
    Layer 1;
    Smd '28' 0.9 0.4 -0 R270 (10.4 5.68);
    Layer 51;
    Rect R270 (10 5.2925) (10.8 5.6675);
    Layer 1;
    Smd '29' 0.9 0.4 -0 R90 (9.6 5.68);
    Layer 51;
    Rect R90 (9.2 5.2925) (10 5.6675);
    Layer 1;
    Smd '30' 0.9 0.4 -0 R90 (8.8 5.68);
    Layer 51;
    Rect R90 (8.4 5.2925) (9.2 5.6675);
    Layer 1;
    Smd '31' 0.9 0.4 -0 R90 (8 5.68);
    Layer 51;
    Rect R90 (7.6 5.2925) (8.4 5.6675);
    Layer 1;
    Smd '32' 0.9 0.4 -0 R90 (7.2 5.68);
    Layer 51;
    Rect R90 (6.8 5.2925) (7.6 5.6675);
    Layer 1;
    Smd '33' 0.9 0.4 -0 R90 (6.4 5.68);
    Layer 51;
    Rect R90 (6 5.2925) (6.8 5.6675);
    Layer 1;
    Smd '34' 0.9 0.4 -0 R90 (5.6 5.68);
    Layer 51;
    Rect R90 (5.2 5.2925) (6 5.6675);
    Layer 1;
    Smd '35' 0.9 0.4 -0 R90 (4.8 5.68);
    Layer 51;
    Rect R90 (4.4 5.2925) (5.2 5.6675);
    Layer 1;
    Smd '36' 0.9 0.4 -0 R90 (4 5.68);
    Layer 51;
    Rect R90 (3.6 5.2925) (4.4 5.6675);
    Layer 1;
    Smd '37' 0.9 0.4 -0 R90 (3.2 5.68);
    Layer 51;
    Rect R90 (2.8 5.2925) (3.6 5.6675);
    Layer 1;
    Smd '38' 0.9 0.4 -0 R90 (2.4 5.68);
    Layer 51;
    Rect R90 (2 5.2925) (2.8 5.6675);
    Layer 1;
    Smd '39' 0.9 0.4 -0 R90 (1.6 5.68);
    Layer 51;
    Rect R90 (1.2 5.2925) (2 5.6675);
    Layer 1;
    Smd '40' 0.9 0.4 -0 R90 (0.8 5.68);
    Layer 51;
    Rect R90 (0.4 5.2925) (1.2 5.6675);
    Layer 1;
    Smd '41' 0.9 0.4 -0 R90 (0 5.68);
    Layer 51;
    Rect R90 (-0.4 5.2925) (0.4 5.6675);
    Layer 1;
    Smd '42' 0.9 0.4 -0 R90 (-0.8 5.68);
    Layer 51;
    Rect R90 (-1.2 5.2925) (-0.4 5.6675);
    Layer 1;
    Smd '43' 0.9 0.4 -0 R90 (-1.6 5.68);
    Layer 51;
    Rect R90 (-2 5.2925) (-1.2 5.6675);
    Layer 1;
    Smd '44' 0.9 0.4 -0 R90 (-2.4 5.68);
    Layer 51;
    Rect R90 (-2.8 5.2925) (-2 5.6675);
    Layer 1;
    Smd '45' 0.9 0.4 -0 R90 (-3.2 5.68);
    Layer 51;
    Rect R90 (-3.6 5.2925) (-2.8 5.6675);
    Layer 1;
    Smd '46' 0.9 0.4 -0 R90 (-4 5.68);
    Layer 51;
    Rect R90 (-4.4 5.2925) (-3.6 5.6675);
    Layer 1;
    Smd '47' 0.9 0.4 -0 R90 (-4.8 5.68);
    Layer 51;
    Rect R90 (-5.2 5.2925) (-4.4 5.6675);
    Layer 1;
    Smd '48' 0.9 0.4 -0 R90 (-5.6 5.68);
    Layer 51;
    Rect R90 (-6 5.2925) (-5.2 5.6675);
    Layer 1;
    Smd '49' 0.9 0.4 -0 R90 (-6.4 5.68);
    Layer 51;
    Rect R90 (-6.8 5.2925) (-6 5.6675);
    Layer 1;
    Smd '50' 0.9 0.4 -0 R90 (-7.2 5.68);
    Layer 51;
    Rect R90 (-7.6 5.2925) (-6.8 5.6675);
    Layer 1;
    Smd '51' 0.9 0.4 -0 R90 (-8 5.68);
    Layer 51;
    Rect R90 (-8.4 5.2925) (-7.6 5.6675);
    Layer 1;
    Smd '52' 0.9 0.4 -0 R90 (-8.8 5.68);
    Layer 51;
    Rect R90 (-9.2 5.2925) (-8.4 5.6675);
    Layer 1;
    Smd '53' 0.9 0.4 -0 R90 (-9.6 5.68);
    Layer 51;
    Rect R90 (-10 5.2925) (-9.2 5.6675);
    Layer 1;
    Smd '54' 0.9 0.4 -0 R90 (-10.4 5.68);
    Layer 51;
    Rect R90 (-10.8 5.2925) (-10 5.6675);
    Layer 21;
    Wire  0.2032 (-11.0084 1.4) +180 (-11.0084 3.4);
    Wire  0.2032 (11.0084 -4.9784) (11.0084 4.9784) (-11.0084 4.9784) (-11.0084 3.4) \
          (-11.0084 1.4) (-11.0084 -4.9784) (11.0084 -4.9784);
    Layer 25;
    Change Size 1.27;
    Change Ratio 8;
    Text '>NAME' R90 (-11.6 -4.8);
    Layer 27;
    Change Size 1.27;
    Change Ratio 8;
    Text '>VALUE' R0 (-6 -0.4);
    Layer 21;
    Circle 0 (-10.4 -4.4) (-10 -4.4);
    Edit 'TSOPII-54.pac';
    Description '\
    <b>54-pin TSOP II</b> (51-85160)<p>\n\
    Source: CYPRESS cy7c1069av33_8.pdf';
    Layer 21;
    Wire  0.1524 \
          (11.2 -4.95) (11.2 4.95);
    Layer 25;
    Change Size 1.27;
    Change Ratio 8;
    Text '>NAME' R90 (-11.4438 -4.9796);
    Layer 27;
    Change Size 1.27;
    Change Ratio 8;
    Text '>VALUE' R0 (-7.9706 -0.6596);
    Layer 1;
    Smd '1' 0.5 1.2 -0 R0 NOCREAM NOSTOP (-10.4 -5.5022);
    Layer 21;
    Wire  0.1524 (-11.2 4.95) (-11.2 -4.95);
    Layer 21;
    Circle 0.1524 (-10.065 -3.935) (-9.5316 -3.935);
    Layer 51;
    Rect R0 (-10.625 -5.863) (-10.175 -4.975);
    Layer 21;
    Wire  0.1524 (11.2 -4.95) (10.85 -4.95);
    Wire  0.1524 (-11.2 -4.95) (-10.8 -4.95);
    Layer 51;
    Wire  0.1524 (-10.8 -4.95) (10.85 -4.95);
    Layer 1;
    Smd '2' 0.5 1.2 -0 R0 NOCREAM NOSTOP (-9.6 -5.5022);
    Layer 51;
    Rect R0 (-9.825 -5.863) (-9.375 -4.975);
    Layer 31;
    Rect R0 (-10.625 -6.05) (-10.175 -4.925);
    Layer 31;
    Rect R0 (-9.825 -6.05) (-9.375 -4.925);
    Layer 29;
    Rect R0 (-10.725 -6.175) (-10.075 -4.85);
    Layer 29;
    Rect R0 (-9.925 -6.175) (-9.275 -4.85);
    Layer 1;
    Smd '3' 0.5 1.2 -0 R0 NOCREAM NOSTOP (-8.8 -5.5022);
    Layer 51;
    Rect R0 (-9.025 -5.863) (-8.575 -4.975);
    Layer 1;
    Smd '4' 0.5 1.2 -0 R0 NOCREAM NOSTOP (-8 -5.5022);
    Layer 51;
    Rect R0 (-8.225 -5.863) (-7.775 -4.975);
    Layer 31;
    Rect R0 (-9.025 -6.05) (-8.575 -4.925);
    Layer 31;
    Rect R0 (-8.225 -6.05) (-7.775 -4.925);
    Layer 29;
    Rect R0 (-9.125 -6.175) (-8.475 -4.85);
    Layer 29;
    Rect R0 (-8.325 -6.175) (-7.675 -4.85);
    Layer 1;
    Smd '5' 0.5 1.2 -0 R0 NOCREAM NOSTOP (-7.2 -5.5022);
    Layer 51;
    Rect R0 (-7.425 -5.863) (-6.975 -4.975);
    Layer 1;
    Smd '6' 0.5 1.2 -0 R0 NOCREAM NOSTOP (-6.4 -5.5022);
    Layer 51;
    Rect R0 (-6.625 -5.863) (-6.175 -4.975);
    Layer 31;
    Rect R0 (-7.425 -6.05) (-6.975 -4.925);
    Layer 31;
    Rect R0 (-6.625 -6.05) (-6.175 -4.925);
    Layer 29;
    Rect R0 (-7.525 -6.175) (-6.875 -4.85);
    Layer 29;
    Rect R0 (-6.725 -6.175) (-6.075 -4.85);
    Layer 1;
    Smd '7' 0.5 1.2 -0 R0 NOCREAM NOSTOP (-5.6 -5.5022);
    Layer 51;
    Rect R0 (-5.825 -5.863) (-5.375 -4.975);
    Layer 1;
    Smd '8' 0.5 1.2 -0 R0 NOCREAM NOSTOP (-4.8 -5.5022);
    Layer 51;
    Rect R0 (-5.025 -5.863) (-4.575 -4.975);
    Layer 31;
    Rect R0 (-5.825 -6.05) (-5.375 -4.925);
    Layer 31;
    Rect R0 (-5.025 -6.05) (-4.575 -4.925);
    Layer 29;
    Rect R0 (-5.925 -6.175) (-5.275 -4.85);
    Layer 29;
    Rect R0 (-5.125 -6.175) (-4.475 -4.85);
    Layer 1;
    Smd '9' 0.5 1.2 -0 R0 NOCREAM NOSTOP (-4 -5.5022);
    Layer 51;
    Rect R0 (-4.225 -5.863) (-3.775 -4.975);
    Layer 1;
    Smd '10' 0.5 1.2 -0 R0 NOCREAM NOSTOP (-3.2 -5.5022);
    Layer 51;
    Rect R0 (-3.425 -5.863) (-2.975 -4.975);
    Layer 31;
    Rect R0 (-4.225 -6.05) (-3.775 -4.925);
    Layer 31;
    Rect R0 (-3.425 -6.05) (-2.975 -4.925);
    Layer 29;
    Rect R0 (-4.325 -6.175) (-3.675 -4.85);
    Layer 29;
    Rect R0 (-3.525 -6.175) (-2.875 -4.85);
    Layer 1;
    Smd '11' 0.5 1.2 -0 R0 NOCREAM NOSTOP (-2.4 -5.5022);
    Layer 51;
    Rect R0 (-2.625 -5.863) (-2.175 -4.975);
    Layer 1;
    Smd '12' 0.5 1.2 -0 R0 NOCREAM NOSTOP (-1.6 -5.5022);
    Layer 51;
    Rect R0 (-1.825 -5.863) (-1.375 -4.975);
    Layer 31;
    Rect R0 (-2.625 -6.05) (-2.175 -4.925);
    Layer 31;
    Rect R0 (-1.825 -6.05) (-1.375 -4.925);
    Layer 29;
    Rect R0 (-2.725 -6.175) (-2.075 -4.85);
    Layer 29;
    Rect R0 (-1.925 -6.175) (-1.275 -4.85);
    Layer 1;
    Smd '13' 0.5 1.2 -0 R0 NOCREAM NOSTOP (-0.8 -5.5022);
    Layer 51;
    Rect R0 (-1.025 -5.863) (-0.575 -4.975);
    Layer 1;
    Smd '14' 0.5 1.2 -0 R0 NOCREAM NOSTOP (0 -5.5022);
    Layer 51;
    Rect R0 (-0.225 -5.863) (0.225 -4.975);
    Layer 31;
    Rect R0 (-1.025 -6.05) (-0.575 -4.925);
    Layer 31;
    Rect R0 (-0.225 -6.05) (0.225 -4.925);
    Layer 29;
    Rect R0 (-1.125 -6.175) (-0.475 -4.85);
    Layer 29;
    Rect R0 (-0.325 -6.175) (0.325 -4.85);
    Layer 1;
    Smd '15' 0.5 1.2 -0 R0 NOCREAM NOSTOP (0.8 -5.5022);
    Layer 51;
    Rect R0 (0.575 -5.863) (1.025 -4.975);
    Layer 1;
    Smd '16' 0.5 1.2 -0 R0 NOCREAM NOSTOP (1.6 -5.5022);
    Layer 51;
    Rect R0 (1.375 -5.863) (1.825 -4.975);
    Layer 31;
    Rect R0 (0.575 -6.05) (1.025 -4.925);
    Layer 31;
    Rect R0 (1.375 -6.05) (1.825 -4.925);
    Layer 29;
    Rect R0 (0.475 -6.175) (1.125 -4.85);
    Layer 29;
    Rect R0 (1.275 -6.175) (1.925 -4.85);
    Layer 1;
    Smd '17' 0.5 1.2 -0 R0 NOCREAM NOSTOP (2.4 -5.5022);
    Layer 51;
    Rect R0 (2.175 -5.863) (2.625 -4.975);
    Layer 1;
    Smd '18' 0.5 1.2 -0 R0 NOCREAM NOSTOP (3.2 -5.5022);
    Layer 51;
    Rect R0 (2.975 -5.863) (3.425 -4.975);
    Layer 31;
    Rect R0 (2.175 -6.05) (2.625 -4.925);
    Layer 31;
    Rect R0 (2.975 -6.05) (3.425 -4.925);
    Layer 29;
    Rect R0 (2.075 -6.175) (2.725 -4.85);
    Layer 29;
    Rect R0 (2.875 -6.175) (3.525 -4.85);
    Layer 1;
    Smd '19' 0.5 1.2 -0 R0 NOCREAM NOSTOP (4 -5.5022);
    Layer 51;
    Rect R0 (3.775 -5.863) (4.225 -4.975);
    Layer 1;
    Smd '20' 0.5 1.2 -0 R0 NOCREAM NOSTOP (4.8 -5.5022);
    Layer 51;
    Rect R0 (4.575 -5.863) (5.025 -4.975);
    Layer 31;
    Rect R0 (3.775 -6.05) (4.225 -4.925);
    Layer 31;
    Rect R0 (4.575 -6.05) (5.025 -4.925);
    Layer 29;
    Rect R0 (3.675 -6.175) (4.325 -4.85);
    Layer 29;
    Rect R0 (4.475 -6.175) (5.125 -4.85);
    Layer 1;
    Smd '21' 0.5 1.2 -0 R0 NOCREAM NOSTOP (5.6 -5.5022);
    Layer 51;
    Rect R0 (5.375 -5.863) (5.825 -4.975);
    Layer 1;
    Smd '22' 0.5 1.2 -0 R0 NOCREAM NOSTOP (6.4 -5.5022);
    Layer 51;
    Rect R0 (6.175 -5.863) (6.625 -4.975);
    Layer 31;
    Rect R0 (5.375 -6.05) (5.825 -4.925);
    Layer 31;
    Rect R0 (6.175 -6.05) (6.625 -4.925);
    Layer 29;
    Rect R0 (5.275 -6.175) (5.925 -4.85);
    Layer 29;
    Rect R0 (6.075 -6.175) (6.725 -4.85);
    Layer 1;
    Smd '23' 0.5 1.2 -0 R0 NOCREAM NOSTOP (7.2 -5.5022);
    Layer 51;
    Rect R0 (6.975 -5.863) (7.425 -4.975);
    Layer 1;
    Smd '24' 0.5 1.2 -0 R0 NOCREAM NOSTOP (8 -5.5022);
    Layer 51;
    Rect R0 (7.775 -5.863) (8.225 -4.975);
    Layer 31;
    Rect R0 (6.975 -6.05) (7.425 -4.925);
    Layer 31;
    Rect R0 (7.775 -6.05) (8.225 -4.925);
    Layer 29;
    Rect R0 (6.875 -6.175) (7.525 -4.85);
    Layer 29;
    Rect R0 (7.675 -6.175) (8.325 -4.85);
    Layer 1;
    Smd '25' 0.5 1.2 -0 R0 NOCREAM NOSTOP (8.8 -5.5022);
    Layer 51;
    Rect R0 (8.575 -5.863) (9.025 -4.975);
    Layer 1;
    Smd '26' 0.5 1.2 -0 R0 NOCREAM NOSTOP (9.6 -5.5022);
    Layer 51;
    Rect R0 (9.375 -5.863) (9.825 -4.975);
    Layer 31;
    Rect R0 (8.575 -6.05) (9.025 -4.925);
    Layer 31;
    Rect R0 (9.375 -6.05) (9.825 -4.925);
    Layer 29;
    Rect R0 (8.475 -6.175) (9.125 -4.85);
    Layer 29;
    Rect R0 (9.275 -6.175) (9.925 -4.85);
    Layer 1;
    Smd '27' 0.5 1.2 -0 R0 NOCREAM NOSTOP (10.4 -5.5022);
    Layer 51;
    Rect R0 (10.175 -5.863) (10.625 -4.975);
    Layer 1;
    Smd '28' 0.5 1.2 -0 R180 NOCREAM NOSTOP (10.4 5.5022);
    Layer 51;
    Rect R180 (10.175 4.975) (10.625 5.863);
    Layer 31;
    Rect R0 (10.175 -6.05) (10.625 -4.925);
    Layer 31;
    Rect R180 (10.175 4.925) (10.625 6.05);
    Layer 29;
    Rect R0 (10.075 -6.175) (10.725 -4.85);
    Layer 29;
    Rect R180 (10.075 4.85) (10.725 6.175);
    Layer 1;
    Smd '29' 0.5 1.2 -0 R180 NOCREAM NOSTOP (9.6 5.5022);
    Layer 51;
    Rect R180 (9.375 4.975) (9.825 5.863);
    Layer 1;
    Smd '30' 0.5 1.2 -0 R180 NOCREAM NOSTOP (8.8 5.5022);
    Layer 51;
    Rect R180 (8.575 4.975) (9.025 5.863);
    Layer 31;
    Rect R180 (9.375 4.925) (9.825 6.05);
    Layer 31;
    Rect R180 (8.575 4.925) (9.025 6.05);
    Layer 29;
    Rect R180 (9.275 4.85) (9.925 6.175);
    Layer 29;
    Rect R180 (8.475 4.85) (9.125 6.175);
    Layer 1;
    Smd '31' 0.5 1.2 -0 R180 NOCREAM NOSTOP (8 5.5022);
    Layer 51;
    Rect R180 (7.775 4.975) (8.225 5.863);
    Layer 1;
    Smd '32' 0.5 1.2 -0 R180 NOCREAM NOSTOP (7.2 5.5022);
    Layer 51;
    Rect R180 (6.975 4.975) (7.425 5.863);
    Layer 31;
    Rect R180 (7.775 4.925) (8.225 6.05);
    Layer 31;
    Rect R180 (6.975 4.925) (7.425 6.05);
    Layer 29;
    Rect R180 (7.675 4.85) (8.325 6.175);
    Layer 29;
    Rect R180 (6.875 4.85) (7.525 6.175);
    Layer 1;
    Smd '33' 0.5 1.2 -0 R180 NOCREAM NOSTOP (6.4 5.5022);
    Layer 51;
    Rect R180 (6.175 4.975) (6.625 5.863);
    Layer 1;
    Smd '34' 0.5 1.2 -0 R180 NOCREAM NOSTOP (5.6 5.5022);
    Layer 51;
    Rect R180 (5.375 4.975) (5.825 5.863);
    Layer 31;
    Rect R180 (6.175 4.925) (6.625 6.05);
    Layer 31;
    Rect R180 (5.375 4.925) (5.825 6.05);
    Layer 29;
    Rect R180 (6.075 4.85) (6.725 6.175);
    Layer 29;
    Rect R180 (5.275 4.85) (5.925 6.175);
    Layer 1;
    Smd '35' 0.5 1.2 -0 R180 NOCREAM NOSTOP (4.8 5.5022);
    Layer 51;
    Rect R180 (4.575 4.975) (5.025 5.863);
    Layer 1;
    Smd '36' 0.5 1.2 -0 R180 NOCREAM NOSTOP (4 5.5022);
    Layer 51;
    Rect R180 (3.775 4.975) (4.225 5.863);
    Layer 31;
    Rect R180 (4.575 4.925) (5.025 6.05);
    Layer 31;
    Rect R180 (3.775 4.925) (4.225 6.05);
    Layer 29;
    Rect R180 (4.475 4.85) (5.125 6.175);
    Layer 29;
    Rect R180 (3.675 4.85) (4.325 6.175);
    Layer 1;
    Smd '37' 0.5 1.2 -0 R180 NOCREAM NOSTOP (3.2 5.5022);
    Layer 51;
    Rect R180 (2.975 4.975) (3.425 5.863);
    Layer 1;
    Smd '38' 0.5 1.2 -0 R180 NOCREAM NOSTOP (2.4 5.5022);
    Layer 51;
    Rect R180 (2.175 4.975) (2.625 5.863);
    Layer 31;
    Rect R180 (2.975 4.925) (3.425 6.05);
    Layer 31;
    Rect R180 (2.175 4.925) (2.625 6.05);
    Layer 29;
    Rect R180 (2.875 4.85) (3.525 6.175);
    Layer 29;
    Rect R180 (2.075 4.85) (2.725 6.175);
    Layer 1;
    Smd '39' 0.5 1.2 -0 R180 NOCREAM NOSTOP (1.6 5.5022);
    Layer 51;
    Rect R180 (1.375 4.975) (1.825 5.863);
    Layer 1;
    Smd '40' 0.5 1.2 -0 R180 NOCREAM NOSTOP (0.8 5.5022);
    Layer 51;
    Rect R180 (0.575 4.975) (1.025 5.863);
    Layer 31;
    Rect R180 (1.375 4.925) (1.825 6.05);
    Layer 31;
    Rect R180 (0.575 4.925) (1.025 6.05);
    Layer 29;
    Rect R180 (1.275 4.85) (1.925 6.175);
    Layer 29;
    Rect R180 (0.475 4.85) (1.125 6.175);
    Layer 1;
    Smd '41' 0.5 1.2 -0 R180 NOCREAM NOSTOP (0 5.5022);
    Layer 51;
    Rect R180 (-0.225 4.975) (0.225 5.863);
    Layer 1;
    Smd '42' 0.5 1.2 -0 R180 NOCREAM NOSTOP (-0.8 5.5022);
    Layer 51;
    Rect R180 (-1.025 4.975) (-0.575 5.863);
    Layer 31;
    Rect R180 (-0.225 4.925) (0.225 6.05);
    Layer 31;
    Rect R180 (-1.025 4.925) (-0.575 6.05);
    Layer 29;
    Rect R180 (-0.325 4.85) (0.325 6.175);
    Layer 29;
    Rect R180 (-1.125 4.85) (-0.475 6.175);
    Layer 1;
    Smd '43' 0.5 1.2 -0 R180 NOCREAM NOSTOP (-1.6 5.5022);
    Layer 51;
    Rect R180 (-1.825 4.975) (-1.375 5.863);
    Layer 1;
    Smd '44' 0.5 1.2 -0 R180 NOCREAM NOSTOP (-2.4 5.5022);
    Layer 51;
    Rect R180 (-2.625 4.975) (-2.175 5.863);
    Layer 31;
    Rect R180 (-1.825 4.925) (-1.375 6.05);
    Layer 31;
    Rect R180 (-2.625 4.925) (-2.175 6.05);
    Layer 29;
    Rect R180 (-1.925 4.85) (-1.275 6.175);
    Layer 29;
    Rect R180 (-2.725 4.85) (-2.075 6.175);
    Layer 21;
    Wire  0.1524 (-11.2 4.95) (-10.875 4.95);
    Wire  0.1524 (11.2 4.95) (10.8 4.95);
    Layer 51;
    Wire  0.1524 (10.8 4.95) (-10.85 4.95);
    Layer 1;
    Smd '45' 0.5 1.2 -0 R180 NOCREAM NOSTOP (-3.2 5.5022);
    Layer 51;
    Rect R180 (-3.425 4.975) (-2.975 5.863);
    Layer 31;
    Rect R180 (-3.425 4.925) (-2.975 6.05);
    Layer 29;
    Rect R180 (-3.525 4.85) (-2.875 6.175);
    Layer 1;
    Smd '46' 0.5 1.2 -0 R180 NOCREAM NOSTOP (-4 5.5022);
    Layer 51;
    Rect R180 (-4.225 4.975) (-3.775 5.863);
    Layer 1;
    Smd '47' 0.5 1.2 -0 R180 NOCREAM NOSTOP (-4.8 5.5022);
    Layer 51;
    Rect R180 (-5.025 4.975) (-4.575 5.863);
    Layer 31;
    Rect R180 (-4.225 4.925) (-3.775 6.05);
    Layer 31;
    Rect R180 (-5.025 4.925) (-4.575 6.05);
    Layer 29;
    Rect R180 (-4.325 4.85) (-3.675 6.175);
    Layer 29;
    Rect R180 (-5.125 4.85) (-4.475 6.175);
    Layer 1;
    Smd '48' 0.5 1.2 -0 R180 NOCREAM NOSTOP (-5.6 5.5022);
    Layer 51;
    Rect R180 (-5.825 4.975) (-5.375 5.863);
    Layer 1;
    Smd '49' 0.5 1.2 -0 R180 NOCREAM NOSTOP (-6.4 5.5022);
    Layer 51;
    Rect R180 (-6.625 4.975) (-6.175 5.863);
    Layer 31;
    Rect R180 (-5.825 4.925) (-5.375 6.05);
    Layer 31;
    Rect R180 (-6.625 4.925) (-6.175 6.05);
    Layer 29;
    Rect R180 (-5.925 4.85) (-5.275 6.175);
    Layer 29;
    Rect R180 (-6.725 4.85) (-6.075 6.175);
    Layer 1;
    Smd '50' 0.5 1.2 -0 R180 NOCREAM NOSTOP (-7.2 5.5022);
    Layer 51;
    Rect R180 (-7.425 4.975) (-6.975 5.863);
    Layer 1;
    Smd '51' 0.5 1.2 -0 R180 NOCREAM NOSTOP (-8 5.5022);
    Layer 51;
    Rect R180 (-8.225 4.975) (-7.775 5.863);
    Layer 31;
    Rect R180 (-7.425 4.925) (-6.975 6.05);
    Layer 31;
    Rect R180 (-8.225 4.925) (-7.775 6.05);
    Layer 29;
    Rect R180 (-7.525 4.85) (-6.875 6.175);
    Layer 29;
    Rect R180 (-8.325 4.85) (-7.675 6.175);
    Layer 1;
    Smd '52' 0.5 1.2 -0 R180 NOCREAM NOSTOP (-8.8 5.5022);
    Layer 51;
    Rect R180 (-9.025 4.975) (-8.575 5.863);
    Layer 1;
    Smd '53' 0.5 1.2 -0 R180 NOCREAM NOSTOP (-9.6 5.5022);
    Layer 51;
    Rect R180 (-9.825 4.975) (-9.375 5.863);
    Layer 31;
    Rect R180 (-9.025 4.925) (-8.575 6.05);
    Layer 31;
    Rect R180 (-9.825 4.925) (-9.375 6.05);
    Layer 29;
    Rect R180 (-9.125 4.85) (-8.475 6.175);
    Layer 29;
    Rect R180 (-9.925 4.85) (-9.275 6.175);
    Layer 1;
    Smd '54' 0.5 1.2 -0 R180 NOCREAM NOSTOP (-10.4 5.5022);
    Layer 51;
    Rect R180 (-10.625 4.975) (-10.175 5.863);
    Layer 31;
    Rect R180 (-10.625 4.925) (-10.175 6.05);
    Layer 29;
    Rect R180 (-10.725 4.85) (-10.075 6.175);
    e14 Contributor over 15 years ago in reply to Richard_H
    Thank you, Richard!
    Unfortunately, my copy of Eagle (4.16r2) doesn't have a memory-micron library, and memory-sram doesn't include this package.
    The FAQ link was helpful... I did not know I could search for a package in the layout editor! Doing so has confirmed that I really don't have a TSOP54 package in any of the libraries I have.
    There are some additional memory-* libraries on the download page. I'll grab some of them and sift through them for the package I desire. (Update: found it in sdram.lbr on the download page.)
  • Richard_H
    may I simply add a link to a FAQ?  ==> http://www.cadsoftusa.com/faq.htm.en#06011302
    There are two SOP54 available: see memory-micron.lbr and memory-sram.lbr
    Richard
