Forum Orphans not working
  • Views 705 views
Orphans not working
I have a new board design which has a ground plane top and bottom. When I Ratsnest - I get told that there is 1 airwire left. After much head-scratching - I found (visually!!) that there is an orphaned section in the bottom layer groundplane. There may be others of course but if they aren't used as a connection I will never know :-((.
Now - the Polygon has Orphans unchecked but it makes no difference whether its checked or not :-(.
NB Using V6.0.0 Light.
So - the question is how do I highlight any orphaned groundplane areas please ???. Then at least I can fix them and not just let them 'float' :-O.
Is this part of the known V6 bug ???.
Many Thanks
Graham
  • Richard_H
    Richard_H over 14 years ago in reply to e14 Contributor
    Hi Graham,
    no problem at all. Great that you could sort it out.
    Richard
    Richard,
    Please accept my apologies :-O.
    Orphans is indeed working in V6.1.0.
    I was getting confused because I had already added a small number of via's just to connect orphaned ground fills :-O.
    Sorry.....
    Best regards
    Graham
    e14 Contributor over 14 years ago in reply to Richard_H
    Richard,
    Thanks for the response, I didn't get the notification email I asked for - hence my delay in picking this up :-O.
    I am already using V6.1.0 :-O. This is where it is failing.....No Orphans being highlighted :-((.
    I'll try the airwire in a while....
  • Richard_H
    Hi Graham,
    I think this is indeed a problem with version 6.0.0. It should work in 6.1.0.
    By the way: How to find an airwire?
    Set the value for Catch factor in Options/set/Misc to 100, activate ROUTE and then click into the drawing.
    The airwire will jump to the mouse cursor.
    Richard
