Forum ground wires and ground pour do not connect
  • Views 449 views
I am having this problem I never had before: my ground wires don't connect to my ground pour.  I make the pour in the usual way, name it GND, hit the ratnest button, but now the pour fills but the wires do not disappear (despite the fact that the pins do look like they are connected to the pour.  The only thing I can think I did differently was use some symbols and packages from a new library.  Any advice will be greately appreciated.  This is driving me crazy.  Thanks, T.
  • robotonics
    robotonics over 14 years ago
    Hi
    As you mentioned that you are using symbols/packages from a new library. I wonder if the power pins of your part are named Vss instead of GND?
    Regards
    David
  • Richard_H
    Richard_H over 14 years ago
    Hi T.
    Did you check the wire width or the isolate values for the polygon? Maybe reduceing the wire width helps. If you don't find the solution, please send me your board file with private email: support @ cadsoft.de
    Richard
