Forum gnd polygon
  • Views 489 views
gnd polygon
Hello RIchard,
I have used a gnd polygon over a certain area of mij pcb including a lot of components of course. I want to exclude an component from this gnd ploygon and give it its own copper trace to GND so it has its own gnd trace to a specific gnd node avoiding it will pickup high current influences. how can I do that in a simple way?
regards,
rob
    e14 Contributor over 14 years ago in reply to Richard_H
    Hello Richard,
    Ah, this works! Thanks.
    regards,
    rob
  • Richard_H
    Richard_H over 14 years ago
    Hi Rob,
    you could draw a restricted area over the component in trestrict or brestrict (depending on where the component is mounted) and connect the pad(s) with a trace(s) directly.
    Richard
