Forum Generate a gerber file with eagles
  • Views 828 views
Hello it's always me !
I have finish to root my card but a new problem.
I would like create a Gerber file  and i do this process :
I Open cam floder
I do File =>open jobs ....
I chose the file Gerb274x.cam
I select  the good layer for my card : "Bottom" "pads"  "vias"  "dimension".
I launch process job but, No file ".GRB" is generating by cam processor  and i have an error message !
other thing all my floder where  my projects is create is locked.
  • Richard_H
    Richard_H over 14 years ago in reply to e14 Contributor
    Hi again......
    Well, if the problem is the file name, simply change the file extensions or add a .gbr for your software.
    Of course you could also change the output files names for your Gerber data in way that you can use it easily...
    You could name the files, for example
    top.gbr  bot.gbr  silk.gbr  solderstoptop.gbr .........
    Richard
    e14 Contributor over 14 years ago in reply to Richard_H
    Yes i have all that :
    %N.cmp  Component side
    %N.sol  Solder side
    %N.plc  Silk screen component side
    %N.stc  Solder stop mask component side
    %N.sts  Solder stop mask solder side
    but my appliance for create  the card "http://www2.ac-lyon.fr/etab/lycees/lyc-42/carnot/UserFiles/Image/charlie2U(2).jpg"  can just read Gerber file "*%N.Gbr" or DFX file i have try with DFX file generate by eagles but the result is not perfect on this appliance ...
    After that i have used a file generate by "Altium" %N.gbr and all is good (but i have not the right to use altium (^_^).
    I have see a documentation where a man use eagles for create a file *.GBR but i think  the file GERB274x.cam is modify.
    Sorry !
  • Richard_H
    the CAM job produces several Gerber files which have different file extensions.
    The following files will be generated:
    %N.sol  Solder side
    %N.gpi   Info file, not needed here
    %N is the placeholder for the board file name without its extension.
    Could you please check?
    regards,
    Richard
