Forum Eagle files PCB for hobby project in a cheap way HOW
  • Subscribers 189 subscribers
  • Views 1071 views
All,
Resent I made two PCB for my project windmeter.
These are two PCB,s one digital and one analog.
Both standard size from the eagle files  100 x 80 mm  double sided  and metalize through..
It looks ok and I have confidence in the way I made the print files chekes where all ok.
Now I woulkd like to have thesew prints fabricated.
I already found out it will cost about 120 euro,s for the both PCB,s which is for me to expencive.
Do some one know a cheaper way to make these PCB,s?
Like to hear,
Theo
    e14 Contributor over 13 years ago in reply to shabaz
    If you make your PCB boards at Elecrow. The price of your two boards maybe less than US $60  plus shipping cost .
    and more, If you purchase US $50 stuff  there, you will get it shipping free. That is to say you can get your PCB boards under US $60.
    hope it will help you
    Regards
    Jackman
    shabaz over 13 years ago in reply to johnbeetem
    Also, whichever option you select from that link, you could possibly halve your cost if you can get both designs onto one board (100x80mm is reasonably large, and it is possible to fit a lot on it, especially if you are using surface mount).
  • johnbeetem
    johnbeetem over 13 years ago
    Here's a discussion on the topic: Cheapest PCB makers, low volume
