Forum OrCAD sch to Eagle software
  • Subscribers 187 subscribers
  • Views 4327 views
  • eagle
  • to
  • schematic
  • orcad
  • software
To Richard Hammerl
I am Shrinivas, I am a PCB designer, currently working an old pcb design software.
Kindly  reply me for the bellow question.
1. Can i import a OrCAD schematics directly to the EAGLE software?
or
2. Can i import OrCAD .net (netlist) and .cmp (Component file) to the EAGLE
software.
Because i have lot of designes in OrCAD, I don't want to enter the schematic again
in the EAGLE, So kindly tell me the procedure to import the design from OrCAD to
EAGLE.
If this possible then i want to switch over to the EAGLE software so the i can update
myself to the EAGLE software.
Thanking you
With regards
Shrinivas.T
    e14 Contributor over 13 years ago in reply to Richard_H
    thanks but  it s not works.
    Manjunath N. Pastey  9819505081
  • Richard_H
    Richard_H over 13 years ago in reply to e14 Contributor
    there is a                  brd_to_dsn_v6.ulp ULP in the CadSoft Download, User Language Program area. This converts a board into DSN format. Do you realy want to convert a schematic into DSN format?
    Richard
    Hi
    can any one reply how to Convert Eagle Sch file into Orcad- DSN file
  • Richard_H
    is it possible to export data in ACCEL-ASCII format from OrCAD? If yes, EAGLE 6.4 could import this as a schematic (File/Import menu). There are also some tools that might help in the www.cadsoft.de download area. Please look into the User Language folder. There is for example
    importbom_and_netlist.zip
    These are a couple of scripts I wrote to facilitate the importing of Orcad schematics into the layout editor. ImportNetlist.ulp imports a PADS2K netlist. ImportBOM (the most useful of both) imports a regular Orcad BOM file and lets you select the package for each group of items. The scripts are not well commented, maybe soon I"ll work on that.
    Uploaded by Jean Simonet  from  -
    In the Tools and Converters section is available:
    or2eag32.zip
    OrCad Wirelist-Format Netzliste zu Eagle Scriptfile Konvertierung (32 Bit Version)
    Uploaded by Jochen Hauer
    and
    nettoz.zip
    It converts netlists from OrCAD or Tango format, placing componets and wires automatically into an eagle board.
    Uploaded by Andrea Tozzi  from  L.E.N.S.
    These might help.
    Best regards,
    Richard
