Forum How do you do a round or other shape PCB...
  • Subscribers 189 subscribers
  • Views 560 views
Ritchie75
Ritchie75 over 13 years ago
Hi all may be this question is very stupid but I can't find the procedure for make a round PCB or other shpae ! because I must to do a PCB for a 19" audio rear PCB with XLR connectors.
My prob is I did the layout with ADOBE ILLUSTRATOR (Rear panel and XLR/Jack...)  and I would want to make the PCB with exact dimensiosn...
Any ideas ?
Thanks for your help
Ritchie
  • fidelsalinas
    fidelsalinas over 13 years ago in reply to Ritchie75
    then this tutorial should help
    Adjust the size of the board outline according to the size of the PCB. The board outline will appear as a square. Left-click on any side of this outline and drag it to the right or left to adjust the size. Keep the shape as a square so that when attempts are made to convert it into a circle, it does not take an oval shape. The sides of the square should be equal to the diameter of the circle. Type "MITER 2" in the command bar on top of the layout, then hit "Enter." The mouse icon will convert into a + sign. Left-click a corner of the square. This will make the corner round. If the rounded corner looks too small, try again with "MITER 3" or any higher number. Similarly, decrease the number if the corner looks too large. Repeat this process to round all corners.
  • Ritchie75
    Ritchie75 over 13 years ago in reply to fidelsalinas
    Hi and thanks to you for your reply, of course I have CADSOFT !!!
    Sincerely
    Ritchie
  • fidelsalinas
    you should download PCB cad software to start. I use eagle but there are a number of others.
