Forum Ratsnest help
  • Views 414 views
Ratsnest help
av8or1
av8or1 over 13 years ago
Hi-
In my current project whenever I do a ratsnest for the board as a whole, the result says that there were 4 airwires.  In my limited experience this usually means that it couldn't make a good ground somewhere.  It can mean other things of course.  Anyway, I have searched every ground and looked elsewhere too, but I cannot find these 4 airwires!  Is there a way you can make Eagle show you where these airwires are located??!?!
  • AnalogNotes
    AnalogNotes over 13 years ago
    Type "display none 19" to show airwires, then you can type "display last" to go back to your previous view...
    Layer 19 is the unrouted layer, in other words, the airwires.
    You can also accomplish the same thing by clicking on the layers icon and deselecting everything, but I find that a bit tedious.  The command line is your friend!
