Forum Eagle 6.4.0 Cadsoft  "Drop''
  • Subscribers 187 subscribers
  • Views 852 views
  • cadsoft
Good day everyone,
I am currently using the Eagle 6.4.0 Cadsoft.
I’ve accidentially pressed on the DROP button and it consequently makes certain Library no longer available in the ADD dialog box.
Is there any way to reinstate my previous Library?
Regards
  • Richard_H
    Richard_H over 13 years ago
    to make libraries available in the ADD dialogue, you can click onto the grey marker in the Libraries list in the EAGLE Control Panel. It turns green then and the library is available again. Also possible: Type USE in the command line or go to the Libraries/Use... menu and select the library file.
    Best regards,
    Richard
