Forum DRU limitations in Freeware License ?
  • Views 313 views
edlofau
edlofau over 12 years ago
HI,
I cannot remove some clearance errors, even decreasing the value of clearance towards 0.
I am running the software as a free user, with the correct dru file loaded in board.
Could it exist any limitation in design rule check for this type of license?
Thanks!
Ed.
  • edlofau
    Solved!
    Class Net Clearance (in schematic) was limiting the clearance parameter in board.
    I used "class" command to see all net classes in schematics. There i changed it and voila...
