Forum Eagle: Does wire going to center of the pad block the hole?
  • Subscribers 187 subscribers
  • Views 452 views
Hi:
Newbie question here: If I route a wire to the center of a pad, won't it be in the way of the pin which needs to go through the hole of the pad? Or does it automatically get drilled out at fabrication? Or should I just have the wire only reaching the edge of the pad and not blocking the hole?
Thanks.
Wallace
    0 e14 Contributor over 11 years ago in reply to dougw
    Thank you Douglas. After I test out my board, I can then approach the manufacturer with a bit of ease about this issue.
    0 dougw over 11 years ago
    The pad will get drilled so traces routed to the center are not in the way of through hole components.
