Forum Difference between PAD and SMD in Eagle cad
  • Views 788 views
I am a newbie with PCB design and EAGLE CAD. I was creating a custom power MOSFET package for my project.I found that in EAGLE CAD there are two options - SMD (red symbol) and PAD (green) to  specify the physical location of the pins. I could not however find when  we have to use SMD and when to use PAD.It would be great  if someone could help me with this.
Note: I checked the master library and found that the power MOSFETS are using PAD's
Thank You
Rahul
    0 e14 Contributor over 10 years ago in reply to shabaz
    Hi Shabaz,
    Thank you very much for your reply. I will look in to the manual.
    Have a nice day!!
    0 shabaz over 10 years ago
    Hi Rahul,
    It is described in the EAGLE PDF manual.
    You can choose which to use dependent on whether you have a through-hole or SMD design.
