Forum Eagle not showing Vcc or Gnd on dual OP AMP DIP
  • Views 4320 views
erdc
erdc over 10 years ago
When I insert a dual OP AMP like the LM358N into a schematic, the first placement shows an OP AMP triangle symbol with just pins 1,2,3 on it, and the next placement show the pins as 5,6,7. But neither pin 4 GND, or pin 8 V+ are being shown so I cannot connect these up.
How does one make these pins visible?
  • 1470aries
    0 1470aries over 2 years ago in reply to kulky64
    Thank you. After so many years, I still tend to forget it, since I don't do schematics that often.
    Not to mention, it seems that Eagle is going the way of the dodo since it will be shut down as of 2026 :-(
    It is now Sept 2024.
  • erdc
    0 erdc over 10 years ago in reply to kulky64
    Thanks kulky64, that worked.
  • kulky64
    0 kulky64 over 10 years ago
    Click on "Invoke" tool, then click on the part and from the list select Gate "P".
