Forum Double sided PCB design
  • Replies 14 replies
  • Subscribers 182 subscribers
  • Views 2447 views
anishkgt
anishkgt over 9 years ago
Hi all,
Since i've started using Eagle, i am now very much familiar with designing one sided. I thought i'd try out double sided.
My idea is to design a PCB with a 11pin connector on one side, 8 led on the other and a POT. So that the connector do not come in the way of the LED when mounting the PCB. below is my design just need some advise if the below design is ok as a double sided design before i send it to the fab house.
  • anishkgt
    anishkgt over 9 years ago +1
    Ok i've done as per advised. Would this as i intent ?
  • kulky64
    0 kulky64 over 9 years ago in reply to anishkgt
    You don't need that one trace in top layer, where all the points are connected by ground pour in the bottom layer.
  • anishkgt
    0 anishkgt over 9 years ago in reply to kulky64
    But would that be only at the bottom ? there is nothing to connect on the top layer and I have no gnd pour on the top layer. Maybe this is what your trying to say
  • kulky64
    Why do you think you need to connect these points redundantly on both layers? One is enough.
  • anishkgt
    I thought my first postwas clear when I said I was trying the double side design.
    My my last post has the ground pour on the top as well thereby avoiding a trace. The previous was without a gnd pour on the top so one side of the r1 and the gnd of vr would seen not connected.
