Forum Z80 Breakoutboard
  • Replies 13 replies
  • Answers 5 answers
  • Subscribers 192 subscribers
  • Views 2458 views
Z80 Breakoutboard
drakkn
drakkn over 9 years ago
Any interest in the Z80 - looking at creating a breakout board?
  • COMPACT
    0 COMPACT over 9 years ago in reply to COMPACT
    The following post has an example of a prototyping PCB made in EAGLE in moments.
    Re: Add holes for through hole components
  • COMPACT
    0 COMPACT over 9 years ago in reply to gdstew
    Once one becomes very proficient with manual PCB layout - you just can't get past making your own!
    Particularly for making SMD to Through Hole adapters.
    I started out laying PCBs using pencil and paper.
    If you want to decrease the component count for a 6502 system use a R6511AQ!
    It's a 6502 microcontroller with the lot. It just needs an external ROM, crystal and a few passives for a minimal practicable system.
    Very cool for the late 1980's!
  • COMPACT
    0 COMPACT over 9 years ago in reply to clem57
    No. It is an Microchannel IBM Token Ring Adapter - Remember the PS/2 systems?
    However I did design commercial MCA and ISA cards.
    0 mcb1 over 9 years ago in reply to gdstew
    I saw an arduino version that was not as cheap.
    Looks like you can buy them here.
    https://the-perf-shop.myshopify.com/collections/frontpage/products/perf-board?variant=4744940737
    Sparkfun had these smaller versions for a while (now discontinued)
    On one side only each hole connected to the one beside it.
    Not quite as handy, but solved some issues.
  • clem57
    0 clem57 over 9 years ago in reply to gdstew
    I have never seen yours gdstew and they do look neat! Can you give link to the kickstarter program or where I can see more?
  • gdstew
    0 gdstew over 9 years ago in reply to COMPACT
    I never said it was a new idea so I have no idea why you think I did. Most perf boards require point to point or wire wrap, this one does not. I'd like to see a picture of the back of that board.
    While making PCBs is expensive in time and money I prefer then and in some cases they are pretty much required (surface mount parts, the bane of modern electronic hobbyist) but they are
    not always the best or easiest solution for small one off projects.
  • clem57
    0 clem57 over 9 years ago in reply to COMPACT
    So is this a PCIe card you plug into a PC with Z80 on it? Did you design and build it?
  • COMPACT
    As my projects show I make PCBs as needed.
    The perf board idea is not new idea.  IBM used this style PCBs of the 1980 and 90's.
  • gdstew
    Has anybody else seen the Perf+ 2 boards ? I have added several pictures from a 6502 computer somebody built with them. Notice, NO WIRES. Connections are made by cutting pads free from or soldering pads to
    traces that all run in one direction on the top, and at 90 deg. angle on the bottom (see connection diagram pictures). I bought 5 of them for $25 when they were getting funding on Kickstarter (I have no other ties with
    this product) and I've been trying to figure out what do do with them. A similar minimal Z-80 project seems like a natural.
  • COMPACT
    0 COMPACT over 9 years ago in reply to dougw
    Yep I have many Z80 systems. Some with just a few chips and 40 year old ones with lots of chips.
    I've even got an ARM mbed working with CP/M on SDCards.
    This page may be of interest.
    https://www.element14.com/community/message/168773/l/is-anyone-interested-with-the-z80#168773
