Forum Z80 Breakoutboard
  • Replies 13 replies
  • Answers 5 answers
  • Subscribers 184 subscribers
  • Views 2161 views
Z80 Breakoutboard
drakkn
drakkn over 9 years ago
Any interest in the Z80 - looking at creating a breakout board?
  • COMPACT
    COMPACT over 9 years ago in reply to gdstew +3
    As my projects show I make PCBs as needed. The perf board idea is not new idea. IBM used this style PCBs of the 1980 and 90's.
  • WestfW
    WestfW over 9 years ago +2 suggested
    Have you seen https://hackaday.io/project/19000 ? A Usable 64k Z80 system in four chips.
  • COMPACT
    COMPACT over 9 years ago in reply to dougw +2 suggested
    Yep I have many Z80 systems. Some with just a few chips and 40 year old ones with lots of chips. I've even got an ARM mbed working with CP/M on SDCards. This page may be of interest. https://www.element14…
  • COMPACT
    0 COMPACT over 9 years ago in reply to clem57
    No. It is an Microchannel IBM Token Ring Adapter - Remember the PS/2 systems?
    However I did design commercial MCA and ISA cards.
  • COMPACT
    0 COMPACT over 9 years ago in reply to gdstew
    Once one becomes very proficient with manual PCB layout - you just can't get past making your own!
    Particularly for making SMD to Through Hole adapters.
    I started out laying PCBs using pencil and paper.
    If you want to decrease the component count for a 6502 system use a R6511AQ!
    It's a 6502 microcontroller with the lot. It just needs an external ROM, crystal and a few passives for a minimal practicable system.
    Very cool for the late 1980's!
  • COMPACT
    0 COMPACT over 9 years ago in reply to COMPACT
    The following post has an example of a prototyping PCB made in EAGLE in moments.
    Re: Add holes for through hole components
