Forum [Request] RF transmitter and receiver library
  • Subscribers 189 subscribers
  • Views 2727 views
  • eagle
  • library
  • receiver
  • transmitter
  • 433mhz
  • rf
aarondz
aarondz over 9 years ago
Hello guys,
Do you guys know where can I get a library for Eagle containing JMR-TX1 transmitter and RXB6-xxx receiver (xxx=433MHz).
  • rachaelp
    0 rachaelp over 9 years ago in reply to aarondz
    You're welcome :-) Please do thoroughly check it before you have any boards built though!
    Best Regards,
    Rachael
  • aarondz
    0 aarondz over 9 years ago in reply to rachaelp
    Thank you very much image
  • rachaelp
    Aaron Warren wrote:
    Hello guys,
    Here is a library I quickly threw together, it's only 0.1" pitch SIL type packages so only took a few minutes to put together.... I've NOT thoroughly checked it so please do so yourself and use at your own risk.
    For future needs it's worth learning how to create library parts yourself. There are some great tutorials out there to help you learn, look on Adafruit and Dangerous Prototypes for some good starting point tutorials and of course thoroughly read the EAGLE manual once you've got a little familiarity with it.
    Best Regards,
    Rachael
    JMR_RF_Lib.lbr.zip
