Forum Novice Question: Why squares around holes
  • Subscribers 187 subscribers
  • Views 428 views
nanok66
nanok66 over 9 years ago
Hello all,
Here goes my first attempt at making gerber files for a PCB fab house.  I am unsure about some very simple things.  I was using the Eagle board editor and for the holes I set them at .35mm diameter but in the board view there is also a square around the hole like in the attached picture.  What does the square represent?
FYI the layers selected for viewing are Pads and Holes.  Which are the only layers I plan to include in the finished gerber file since this is an inductor coil PCB.   Is that ok to do?
  • e14softwareuk
    0 e14softwareuk over 9 years ago
    Hi. What layers are the squares on? Could they be your drill legends?
