Forum Anyone using Raspberry Pi zero W
  • Subscribers 189 subscribers
  • Views 1042 views
  • eagle 7.6
  • pi-zero
genebren
genebren over 8 years ago
Greetings,
I have a client that would like to move his design over to a daughter board for the raspberry pi zero.  Has anyone created an Eagle library for a daughter board?  Any tips or suggestions for designing within this environment?  Any ideas on to suitable mating connector for the I/O pins (through hole or SMT)?
Thanks in advance for any help or assistance.
Gene
    0 genebren over 8 years ago in reply to rsc
    Very interesting....  I had not thought of a right angle connector, and I'm still not sure that it would help.  But it does give the mind something to chew on.
    Thanks!
  • rsc
    0 rsc over 8 years ago
    Depending on the size of the box and where you need to get at pins and connectors, a right angle 40-pin might be an answer.
    https://learn.adafruit.com/introducing-the-raspberry-pi-zero/a-tour-of-the-pi-zero https://learn.adafruit.com/assets/28775
