Forum Layer 15 (Route 15) used but not enabled
  • Subscribers 189 subscribers
  • Views 864 views
sebbe
sebbe over 8 years ago
Hi there.
I have Eagle 7.7.0 and have 8 sheets in my schematic. I have the maker license and have no layer 15 available (only 1 & 16). Is there a way for me to identify what I have on layer 15 so I can somehow remove this and if required create this on layer 1 or 16?
Kind regards,
Seb
  • sebbe
    0 sebbe over 8 years ago in reply to genebren
    Excellent advice Gene!!!
    Opened in Notepad++, did a search on layer="15" and replaced it with "16".
    Saved the file and opened Eagle again. Worked like a charm :-)
    Thanks again Gene
    0 genebren over 8 years ago
    Seb,
    I don't know of a way to do it from within the Eagle program, but you can open the '.brd' file in a text editor.  The file is very much like an HTML file.  Search for: layer="15" to find any entries on that layer and edit them onto a visible layer.  Then save the file and reopen it in Eagle and take care of the problem from there.
    Not the cleanest way, but it should work.
    Good luck.
    Gene
