Forum eagle library needed
  • Subscribers 189 subscribers
  • Views 1050 views
faad021
faad021 over 8 years ago
Hello everyone,
Is there any eagle  library available for the this component?
    0 genebren over 8 years ago in reply to faad021
    I can see where it might be a little difficult to generate a library element from that description.  Difficult but not impossible.
    Best of luck!
    Gene
  • faad021
    0 faad021 over 8 years ago in reply to genebren
    hi,
    here is a link to the part i am searching for.
    https://www.elv.de/output/controller.aspx?cid=74&detail=10&detail2=2274
    i tried using samacsys to generate a library for this part but unfortunately the datasheet does not have enough information to create one.
    Thanks for the links though.
    faad
    Do you have a part number and/or manufacturer for these dome keys?  I looked around, but could not find anything similar to your pictures.
    If you are interested in creating a library element for you switches, here are links to some excellent tutorials on library creation:
    EAGLE Tutorial: Library Part Creation Part 1 - Creating Packages
    EAGLE Tutorial: Library Part Creation Part 2 - Creating Symbols
    EAGLE Tutorial: Library Part Creation Part 3 - Creating Devices
    EAGLE Tutorial: Library Part Creation Part 4 - Advanced Packages and Package Variants
    EAGLE Tutorial: Library Part Creation Part 4b - Supplemental worked example
    EAGLE Tutorial: Library Part Creation Part 5 - Multiple Symbol Devices
    EAGLE Tutorial: Library Part Creation Part 6 - Adding Attributes and Technologies
    Good luck,
    Gene
  • faad021
    Hi
    thanks for your reply. It’s a triangular metal dome key but i still can’t find it under dome-key.lib . I am not quite experienced with eagle in creating a lib.
    thanks
    It is not clear from your image the size of the battery that the clip is intended for. The Eagle library battery.lib contains some coin cell battery clips.  You might be able to find a suitable component from this library, or you could create your own library for the part you are interested in.
    Good luck,
    Gene
