Forum Eagle 9.1.0 Crashes almost everytime I use a file selection window, how to fix?
  • Subscribers 187 subscribers
  • Views 947 views
robws@quayconsulting.net
robws@quayconsulting.net over 8 years ago
I have recently started using Eagle to do actual designs and almost every time I need to use the file selector (EG to save a file under a new name, select a cam file to process, etc) I get part way through the process of selecting the file/directory and it crashes.
Any Ideas how to fix??  It makes it really hard to use.
Note actual file I/O such as ctrl-s to do a save works completely flawlessly.
Running version 9.1.0
  • Jorge_Garcia
    0 Jorge_Garcia over 8 years ago
    Hi Robert,
    I hope you're doing well. That's really unusual.
    The first thing I would like to recommend is to update to V9.1.3 and see if the problem continues. If it does, please zip up the crash dumps (relatively new feature) and send them to jorge.garcia@autodesk.com. You will find the crash dumps in the following location:
    Windows: $HOME\AppData\Roaming\Eagle\crash-dumps\X.Y.Z
    MacOS: ~/Library/Application\ Support/Eagle/crash-dumps/X.Y.Z
    Linux: ~/.local/share/Eagle/crash-dumps/X.Y.Z
    Best Regards,
    Jorge Garcia
    Feel free to visit us on our Autodesk Forums https://forums.autodesk.com/t5/eagle-forum/bd-p/3500
