Forum MQ-2
  • Answers 2 answers
  • Views 3302 views
MQ-2
allenbubb
allenbubb over 7 years ago
Good day.
i am looking for the mq-2 lbr. with out the board just the sensor . with its points.
Thank you
    0 dougw over 7 years ago
    These types of sensor can wear out, so it might be better to install a socket:
    Note that the socket has a different footprint than the sensor.
    Also note that some MQ sensors have different pin diameters even though the pitch is the same.
    I put both socket and sensor footprints on the PCB.
  • mp2100
    0 mp2100 over 7 years ago
    I don't know where you are located, but I assume ebay could work for you.  I've noticed some sellers have the bare sensor without the board.  I assume most/all are from China.
    For example:
    https://www.ebay.com/itm/MQ2-MQ4-MQ5-MQ7-MQ9-MQ6-MQ8-MQ135-Gas-Propane-Methane-Butane-Sensor-With-Base-S/182400157454?ha…
    that one has a variety of MQ-x sensors.
    This one is specifically has the MQ-2:
    https://www.ebay.com/itm/MQ2-Gas-Sensor-for-LPG-Propane-Hydrogen/181266971481?hash=item2a345a7b59:g:aLUAAOSwuMFUj~EN
    I have NOT bought from these vendors, so I'm not endorsing them.  I'm just saying that there are several sellers on ebay you could try.
